Digihome Vestel 500UNDC TV loses picture after a few seconds
  • tonydix
    • Dec 2013
    • 31
    • Panama
    Vestel 500UNDC using a vestel 17PS20 power board. Backlights come on and picture shows for a few seconds and then goes dark. Sound is fine. Is this a problem with the led strips or the backlight driver ? Many thanks
  • cheeky2
    • Dec 2012
    • 337
    • uk
    Re: Digihome TV loses picture after a few seconds
    More than likely the leds. But as you haven't stated whether you have checked anything then it could be either! I suggest you get your meter out and check the output voltage for the leds. One lead on chassis other on the output connector. Check for highest voltage across the terminals.
    • tonydix
      • Dec 2013
      • 31
      • Panama
      Re: Digihome Vestel 500UNDC TV loses picture after a few seconds
      I have tested the leds with my home built LED tester. They light up and if you power on the rest of the set we get a normal picture ( a little dim with my led tester) and sound.
      In normal operation the leds come on for just a second So it appears that the drive circuit is shutting down. Thanks for your response.
      • cheeky2
        • Dec 2012
        • 337
        • uk
        The problem could be with either! Led testers do not output the correct driver current compared to the psu led driver circuit and I have had led connectors go slightly high resistance and shut down the driver board! This has caused hours of head scratching before! If you suspect this then best way to check is to see if the output voltage is fluctuating on the led tester. It will be a good indicator as to issues with the leds or the connectors between the strips. Checking the connectors is easiest carried out by monitoring the voltage drop across the connectors. If it is very low then good if it higher compared to other connectors then wire bridge the connector. Obviously you will have to use the led tester to check the voltage drop across the connectors.
        Good luck
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • nick4275
          Vestel Based JVC no picture, leds on
          by nick4275
          Hoping someone has troden this path before !
          I'm looking at a JVC LT-39c790 - a vestel based unit.
          So, the remote turns it on, led's light up but no picture at all.
          I have a spare mainboard, so I know its not that. The PSU seems ok too.
          On the AUO T-Con I've got 16v on HAVDD_H but nothing on HAVDD_L - which I'm assuming should also be 16v ?
          So, Ive resorted to testing eveything I can on the board as I can't find any schemas for it (AUO 39T15 C04 Ctrl Bd) and I think I've found a diode gone short. it marked D005 on the board and E1 on the package...
          11-21-2023, 04:43 AM
        • freccia
          Vestel 42 inch VES420UNDL no picture, backlight ok, sound ok
          by freccia
          I have a Finlux/Vestel Led Tv with the following fault and cannot reason from where the fault is. Fault is:
          Sound ok, Backlight ok, Picture nothing but colour vertical lines. power supply vestel 17 IPS 71, main board 17MB82S
          Checked 12V on tcon on fuse ok.
          Checked 12v and 24v on power supply ok.
          Volume works. removed l left ribbon cable no picture white on half, and same with right one.
          Any idea from where I can start please?
          Any help appreciated please....
          01-09-2022, 05:14 AM
        • classypenguin
          TV Telefunken (Vestel) D50U660R2CW - on the tv screen but every 3-4 seconds lines appear on the screen flickering
          by classypenguin
          Hey, I got an Telefunken 4K D50U TV in for repair. Since the problem is t-con flex related, I isolated the problem to one side (right flex of the t-con). I taped the flex a bit, but i couldnt get any further. I attached the pictures of the t-con board in zoom in perspective. I would appreciate help for this TV. Please note that I came from Germany, so it is a bit difficult with the time zones. Greeting Tobi...
          08-29-2024, 03:47 PM
