Un50mu6070 Mainboard issue
  • Storyteller12
    • Jun 2020
    • 624
    Re: Un50mu6070 Mainboard issue
    I just got a cheap ch341a to start with.
    I’ll dump the chip again tomorrow and upload again.
    Thanks for the help
    Appreciate it
    • lotas
      • Jan 2016
      • 4458
      • Russia
      And what soft do you have for the programmer?
      Here is the latest version of "Colibri" for the CH341A.
      • Storyteller12
        • Jun 2020
        • 624
        I’m using AsProgrammer. I’ll try colibri and see if that makes a difference
        • lotas
          • Jan 2016
          • 4458
          • Russia
          Driver ch341
          • lotas
            • Jan 2016
            • 4458
            • Russia
            Today I checked with "Colibri", it does not save "STATUS REGISTERS", let's stop at AsProgrammer_2.1.0.13 everything is fine with it.
            • Storyteller12
              • Jun 2020
              • 624
              Ok. Tried again using your version of colibri, and asprogrammer. Still not working.
              Everything says successful but nothing
              I tried dumping my eeprom that does work and writing that but nothing.
              Thinking it may be the chip itself is just bad and not reusable.
              • lotas
                • Jan 2016
                • 4458
                • Russia
                #27
                I will now write the correct order of actions in AsProgrammer.
                It doesn't work on Colibri.
                • Storyteller12
                  • Jun 2020
                  • 624
                  Thanks lotas. You been more than helpful.
                  I appreciate you
                  • lotas
                    • Jan 2016
                    • 4458
                    • Russia
                    #29
                    In the program:
                    1. Click "Detect Chip" and select W25Q40CL and "Select IC".
                    2. Click "Unprotect".
                    3. Click "Erase IC" and "Yes".
                    4. Click "Open File" and select your corrected Dump.
                    5. Press "Program IC" and "Yes".
                    6. Click "Verify IC".
                    7. Press the down arrow to the right of "Unprotect" and select "Edition SREG", put a check mark on S7, S3, S14, S9 and press "Write" and "Yes"
                    7. Close the program. Ready.
                    • Davi.p
                      Hobbist
                      • Sep 2009
                      • 4264
                      • Italy - Milan
                      #30
                      Reading back i don't know why i have written my first post, you don't even have described the tv symptoms...
                      • Storyteller12
                        • Jun 2020
                        • 624
                        Thanks Lotas, but still won't work.
                        I did exactly as you wrote.
                        I also tried another chip I found on another mainboard I had laying around and same results.
                        I made sure the registers were 0x88 and 0x42.
                        I must be doing something wrong.
                        • Storyteller12
                          • Jun 2020
                          • 624
                          Davi.P:
                          You were right though.it’s definitely that eeprom that’s bad. All I did was swap eeprom from a 55” mainboard I had and it works.
                          I’m just trying to figure out why the eeprom I’m programming will not work. it’s definitely the eeprom.
                          • Davi.p
                            Hobbist
                            • Sep 2009
                            • 4264
                            • Italy - Milan
                            #33
                            The only possible answers i find is that that chip has some hidden / secret command made for Samsung to make programmed obsolescence, i mean a command to read/write a secret register where it is wrote: "this tv is young / this tv is old and needs to die in a reciclery". Try to find its datasheet, if i'm right you'll not find it..
                            • lotas
                              • Jan 2016
                              • 4458
                              • Russia
                              #34
                              Try this dump
                              • lotas
                                • Jan 2016
                                • 4458
                                • Russia
                                #35
                                When dismantling and installing the 25Q40, were they not damaged, did the adjacent components move?
                                • Storyteller12
                                  • Jun 2020
                                  • 624
                                  I thought that also. So I switched back the eeprom I took from the 55” tv it still works fine.
                                  Also I tried to dump the working eeprom I have and write it but It's still not working. Getting frustrated with it
                                  • Davi.p
                                    Hobbist
                                    • Sep 2009
                                    • 4264
                                    • Italy - Milan
                                    #37
                                    you would need a logic analyzer like cheap Saleae and the right software to back engineering what the tv asks to the memory...
                                    • lotas
                                      • Jan 2016
                                      • 4458
                                      • Russia
                                      #38
                                      Storyteller12 What is your CH341A programmer, there are several types of them (black, green ...) post a photo of it.
                                      • Storyteller12
                                        • Jun 2020
                                        • 624
                                        Im using this programmer
                                        • lotas
                                          • Jan 2016
                                          • 4458
                                          • Russia
                                          #40
                                          Refinement of the programmer
                                          In the process of working with the programmer, some shortcomings were revealed,
                                          one of them: it is not possible to clear / set the QE bit in the second status register.
                                          We read the datasheet, for example, on the W25Q64FV chip, and find the Quad Enable (QE) punt,
                                          which has a warning:
                                          WARNING: If the / WP or / HOLD pins are tied directly to the power supply or ground during
                                          standard SPI or Dual SPI operation, the QE bit should never be set to a 1.
                                          To fix this flaw, you need to disconnect the legs #WP (pin 3) and #HOLD (pin7) from VCC
                                          and connect them to VCC through 4.7 kΩ resistors.
                                          I propose a step-by-step instruction for finalizing the "black programmer":
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • eclectric
                                            Sony Bravia KDL-70W850B T-CON board / software update issue
                                            by eclectric
                                            Hi, I'm hoping someone can help me with this issue before I give up on this TV.
                                            In short, I replaced the T-CON board due to an error code indicating that was the problem, after which it flashed a green and orange LED meaning software update required. I cannot get the tv to do the required update via USB, so I am stuck.
                                            Here is a rundown of the symptoms and the steps I have taken to troubleshoot:
                                            I inherited the TV with the symptom that it would turn on, then turn off after 5-10 seconds and a red LED flashed 4 or 5 times. Sometimes it would be 4, sometimes...
                                            05-23-2022, 01:25 AM
                                          • corrize
                                            Nikon D5 – dead, power board issue ?
                                            by corrize
                                            Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                            When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                            I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                            Now, I try to understand how it works.
                                            There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                            04-03-2023, 09:13 AM
                                          • damndenis
                                            ASUS VG32UQA1A t-con board issue
                                            by damndenis
                                            Hello everybody,
                                            This is my first post here, I've always loved to tinker with electronics, but never got in-depth with it. Hope I can learn a thing or two from this forum.
                                            I've got a 31.5" Asus monitor which distorts/flickers at equal intervals of a couple of seconds. From what I've gathered, it's an issue with the T-CON board, but feel free to correct me. Shipping from the manufacturer would cost 3x as much as the part itself. I was wondering, if there is a way to diagnose the board itself and replace the faulty components? I'm good with soldering, but not at all...
                                            11-22-2024, 04:07 AM
