Le32b530p7xxc
  • nezocas
    • Oct 2015
    • 27
    • Alcanena
    Le32b530p7xxc
    Need some help,
    Tv boots up with Samsung startup sound, I have visible image in the back ground with flasligth and also sound, But NO backligth.
    On the CN801 connector from the BN44-00261B all voltages are present:
    Pin 1: OFF 0v. Out of standby 1.55v
    pin 3: 5.24v
    pin 7,8: 13v
    pin 13,16: 5.2v
    pin 19: 13v
    pin 21,22: 13v
    pin 23: 4.46v
    pin 25: 2.15v
    pin 27: 0v
    I have tested:
    DI823 DI811 and DI810
    Got both transformers out and their are 5homs apart in all the secondary windings
    Replaced the FAN7530
    Change place of bolth KA431 present in the board ICM845 and ICS801
    Dissassembled the lcd and checked the all the U shaped CCFL´s with an ccfl tester
    If I disconnect the mainboard the backligth isnt present
    PFC 390v present on tha mains cap
    All caps not tested with ESR meter....but they dont seem bad
    Not sure what to do next
    Best regards
    Nezocas
  • nezocas
    • Oct 2015
    • 27
    • Alcanena
    Re: Le32b530p7xxc
    Any help?
    Regards
    Nezocas
    • lotas
      • Jan 2016
      • 4749
      • Russia
      Re: Le32b530p7xxc
      BN44-00261B schematic
      • cheeky2
        • Dec 2012
        • 337
        Re: Le32b530p7xxc
        I had one of these the other day with the same symptoms. Looking at the power board and combined inverter the transformer on one of them was burn't out on the windings.
        The windings input winding around 13 ohms the two secondary windings are around 1200 ohms on an original unit and around 800 ohms on a replacement winding.
        That's where I would look first.
        • nezocas
          • Oct 2015
          • 27
          • Alcanena
          Re: Le32b530p7xxc
          As stated in my first post, the transformers winding were tested, out of circuit.....Now I dessoldered them again to write values.... didnt find much diferences between them:
          1º transformer:
          Primary 12.35R
          1º secondary 828R
          2º secondary 830R
          2º transformer
          Primary 12.35R
          1º secondary 841R
          2º secondary 841R
          Not sure if this diference will make any change.
          • cheeky2
            • Dec 2012
            • 337
            Re: Le32b530p7xxc
            Then I would look at the high voltage capacitors on the output side of the inverter 5pf 6KV for breakdown. I would imagine that the feedback circuit of the high voltage side is activating for whatever reason normally as a result of failed ccfl's however you state that you have checked these. So I would check all the components that activate this circuit. You can temporarily bypass the protection circuit by inserting 82k resistor see attached picture however do not use it as a solution to your issue.
            Just be extremely careful to ensure you don't use it for long as can cause fatal damage to you as a result of the very high voltages on the combined inverter psu!
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • mikey5791
              Help on Samsung Syncmaster T220 dead ccfl lamp
              by mikey5791
              This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
              Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
              10-18-2020, 03:17 AM
            • valente222
              HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
              by valente222
              I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
              there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
              n, please identify.
              330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
              SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
              I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
              06-27-2024, 06:11 PM
            • air_chair256
              Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
              by air_chair256
              I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
              Tried to reball RAM 1,2,3,4
              Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
              02-13-2024, 06:00 AM
            • javieromex
              Dell G15 5511 LA-K452P won't turn on
              by javieromex
              Hello, any help will be apprecited!
              • Model: Dell G15 5511
              • MB: LA-K452P
              • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
              • Customer reported it was turned off and left plugged in during the night and thats it...
              • No signs of liquid damage or burned components.
              Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
              I have checked so far:
              04-17-2025, 12:44 PM
