55PUS6031 Vestel 17MB120 reboot
  • morind79
    • Sep 2021
    • 9
    • France
    Hi All,
    I have a Philips TV 55PUS6031 that is rebooting all the time.
    I heard it was due to the firmware that is corrupted.
    So I have flashed a new firmware (that was for Philips using Vestel) so now the TV can boot normally.
    But screen was rotated 180° but remote control is working fine.
    I first thought I used the wrong firmware so used another one (that was for OEM using Vestel) but still the same.
    But now I have another issue is the remote control is not working anymore !
    So I cannot flash a new firmware as I need the remote control OK button.
    How can I solve my issue ?
    I would like to reflash the first firmware I have used.
    I am able to connect to the TV via telnet (using Vestel toolbox), do you know if I can change the remote control settings ?
    Thank you.
    Denis
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: 55PUS6031 Vestel 17MB120 reboot
    Keep pressing ok and you should be able to flash the firmware even if your remote dosen't work. I know it dosen't make sense but give it a try. Then I can help you rotate the screen or I can find you the exact firmware for your tv.
    • yokoono
      • Apr 2010
      • 511
      If the OK key is not functional, try a programmable remote control.
      • morind79
        • Sep 2021
        • 9
        • France
        thank you for your answers.
        I tried OK button several times, but still does not work.
        I have an old programmable RC I will try with that.
        Otherwise, maybe there is a file I can modify to be compatible with the remote ?
        I have access to the Linux files via Telnet.
        • ducky29
          • Dec 2015
          • 369
          • Europe
          Try another method. Press press press rapidly instead of holding it. Sorry I don't know any method via telnet.
          • morind79
            • Sep 2021
            • 9
            • France
            No luck so far :-(
            • morind79
              • Sep 2021
              • 9
              • France
              I finally get it working with a Toshiba remote control.
              So I have set a new firmware and original RC is working again.
              But still image is rotated 180° :-(
              I try going in service menu, but without success for the moment.
              • ducky29
                • Dec 2015
                • 369
                • Europe
                Sent you a pm with instructions and files.
                • hosbulduk
                  • May 2020
                  • 17
                  hw profile file contains remote control settings. If you know how to change the code of your Philips remote control in the hw profile, if it becomes active again or if you find a Vestel TV remote control, your problem will be solved and the software you have installed will be applied to another remote control. , therefore the Philips remote control is not active The code is in the battery compartment.
                  • morind79
                    • Sep 2021
                    • 9
                    • France
                    I have reflashed using a Toshiba remote control.
                    So the Philips RC is working now.
                    Still issue with flipped image.
                    • yokoono
                      • Apr 2010
                      • 511
                      Enter the panel code: VES550XXXXXXX.
                      • hosbulduk
                        • May 2020
                        • 17
                        It is possible to solve the mirror screen problem by installing the panel software. It is possible to find the software of TV brands made in Turkey on the Turkish forum by their serial numbers, the link I shared in another topic. But I solve the problem by just trying the panel software released according to the motherboard group on the export product TVs. Today I installed the mb170 android motherboard to the mb120 motherboard and got a mirror image.I have to look for the right software in the panel software.
                        • morind79
                          • Sep 2021
                          • 9
                          • France
                          The panel is : ves550qnds-2d-u11
                          • yokoono
                            • Apr 2010
                            • 511
                            Unfortunately I do not have a panel profile for 17MB120 and VES490QNDL-2D-U11.
                            • hosbulduk
                              • May 2020
                              • 17
                              No matter which panel you have, as yokoono wrote, you cannot find software by the serial number because it is an export production television. In this case, I'll try to find the right software by trying the panel software listed for my motherboard one at a time. When you search for "Tavsiyeforumu Panel yazilim" on google or click the panel software link I shared on other topics. You can use the software grouped by motherboard to access the panel software archive and try out the software suitable for your motherboard.
                              • ducky29
                                • Dec 2015
                                • 369
                                • Europe
                                You are correct it might be very hard to find the firmware but I sent him the exact firmware based on the serial number. Tavsiye has only firmwares for vestel and other turkish brands and not exports like toshiba, philips, bush, luxor, jvc etc etc; which I can source. Nowdays theres a lot of variety in the vestel firwmare starting from rc, logo, panel, smart-non smart, sound, reception etc etc so its a pain in the ass trying to find the correct combination.
                                • morind79
                                  • Sep 2021
                                  • 9
                                  • France
                                  With the latest firmware everything is working fine !
                                  A big thank you for all your support.
                                  • yokoono
                                    • Apr 2010
                                    • 511
                                    1. So is VES550QNDS-2D-U11 no VES490QNDL-2D-U11
                                    2. Do you not post here the used software?
                                    • Ginkgo
                                      • Apr 2022
                                      • 3
                                      • Spain
                                      Hello. I have the same problem as you. I need to reinstall the firmware of my 55pus6031. I did but the file was wrong. The television is rotated 180 degrees and only responds to the Toshiba remote. Would you still have the appropriate software? Thank you
                                      • morind79
                                        • Sep 2021
                                        • 9
                                        • France
                                        Hi, sorry I do not have it anymore
                                        • cheeky2
                                          Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                                          by cheeky2
                                          I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                                          Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                                          The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                                          Details:...
                                          08-17-2023, 04:34 AM
                                        • Bazilwrc164
                                          Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                                          by Bazilwrc164
                                          I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                                          The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                                          I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                                          If anyone can provide:
                                          • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                                          • Or a compatible EEPROM dump
                                          07-23-2025, 12:15 PM
                                        • massimomax
                                          Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                          by massimomax
                                          Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                          spero che qualcuno può averlo per riprogrammare eprom. grazie
                                          Post in English !!!
                                          I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                          02-28-2025, 07:27 AM
                                        • lberkani
                                          Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
                                          by lberkani
                                          I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
                                          The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
                                          The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
                                          I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
                                          - Toshiba 65UL2163DG
                                          - Vestel 17MB180E mainboard
                                          - Panel VES650QNTX-N2-N42
                                          - Version V1.28.100.0 if available
                                          If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
                                          11-11-2025, 12:37 PM
                                        • anlu
                                          Vestel Firmware - Toshiba 32W133DN
                                          by anlu
                                          Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                                          Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                                          02-04-2023, 12:59 AM
