55PUS6031 Vestel 17MB120 reboot
+ More Options
Posts
  • yokoono
    • Apr 2010
    • 481
    Re: 55PUS6031 Vestel 17MB120 reboot
    Originally posted by Ginkgo
    Hello. I have the same problem as you. I need to reinstall the firmware of my 55pus6031. I did but the file was wrong. The television is rotated 180 degrees and only responds to the Toshiba remote. Would you still have the appropriate software? Thank you
    Copy the TV profile (profile+pq) on a stick and post it here.
    • Ginkgo
      • Apr 2022
      • Spain
      maybe this information will help. Thank you so much
      • lotas
        • Jan 2016
        • 4555
        • Russia
        You did not try to download this native firmware
        https://www.p4c.philips.com/cgi-bin/...scy=GB&slg=ENG
        • Ginkgo
          • Apr 2022
          • Spain
          Thanks for the reply. The firmware installs successfully but the Philips remote still doesn't work and the screen is still rotated 180 degrees.
          • Cornito
            • Jan 2024
            • 90
            • France
            Sorry for reopening this post but I've got the same kind of issue.
            Reflash Philips 43pus6031 with the generic Vestel firmware.
            And now tv is working but stuck on first installation.
            I'm not able to add the new pin code because remote is not appeared anymore.
            Is there any possibility to reflash without the remote or modify the software parameters to force the Philips remote?
            Regards
            • Cornito
              • Jan 2024
              • 90
              • France
              #26
              Auto Reply,
              I needed to use universal remote control with Vestel parameters in order to move forward.
              I didn't found any solution to set back the original remote
              • cheeky2
                Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                by cheeky2
                I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                Details:...
                08-17-2023, 04:34 AM
              • massimomax
                Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                by massimomax
                Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                spero che qualcuno può averlo per riprogrammare eprom. grazie
                Post in English !!!
                I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                02-28-2025, 07:27 AM
              • anlu
                Vestel Firmware - Toshiba 32W133DN
                by anlu
                Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                02-04-2023, 12:59 AM
              • piernov
                Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                by piernov
                Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                I suspect corrupt firmware but I haven't been able to find anything for this TV.
                TV model: Finlux 65-FUC-8060
                Mainboard: Vestel 17MB130S 23473048
                Panel: VES650QNTS-2D-U11
                At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                06-01-2024, 12:57 PM
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
