UN55NU7100 Samsung no power on, red blinks
  • videotronics
    • May 2013
    • 22
    On plug in the red led blinks one long three short one long two short repeating, the power supply smells burnt, A13v on CNM801 pins 3,5,7,9 is 12.8 volts, it drops to 10.8 volts when the led is on long blink, pson pin 8 is at 3.2 volts dropping to 0.11 volts on long blink, the test point jumper marked STB:7.5 ON:11.8 measures 12.8 volts dropping to 10.8 volts on long blink. The set is powered down on the long blink and reboots while short blinking? Can someone help me find a test point for the run supplies?
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: UN55NU7100 Samsung no power on, red blinks
    what power supply board is used in this tv is a BN4400932C
    • Superbee_dad
      Sharp 80” long short flash backlight error - Help
      by Superbee_dad
      Hello Sharp TV experts
      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
      01-24-2025, 11:51 PM
    • Tom_x
      HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
      by Tom_x
      I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
      HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
      Now with blinking capslock:
      All voltage present on big coils, except +VCCGT (i don't know this need for booting)
      I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
      DDR4 ram is ok, tested on other laptop
      WLAN and SSD removed,...
      07-20-2023, 10:10 PM
    • EazyBone
      Un50cu7000 2 blink oddity *partially solved
      by EazyBone
      I write this to maybe help another with this TV.
      So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
      The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
      03-18-2024, 10:24 PM
    • Loretto
      Samsung SMPS BN44-00339A
      by Loretto
      this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
      I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
      I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
      I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
      03-29-2025, 08:30 AM
    • Loretto
      by Loretto
      03-28-2025, 10:28 AM
