Samsung BN44-00623D power board - identifying blown cap
  • Rynobomb
    • Aug 2021
    Does anyone have a schematic for this board? I'm looking for the value of CP816, mine is toast and cannot be read. It may be the same as the one close to it based on size but I want to be sure. I looked for the schematic online but could only find similar boards and not this exact one.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8112
    Re: Samsung BN44-00623D power board - identifying blown cap
    Maybe we can guess it? Post a picture of the board and another one around the area that cap is.
    • R_J
      • Jun 2012
      • 9535
      It is likely a 220pF 1kv, replace with a 2kv cap. It will be the same as CP806
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • cmlewis89
        LG 47LB5DF blown power supply board
        by cmlewis89
        Hi folks,
        I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
        09-03-2024, 07:50 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
        09-07-2024, 05:50 AM
      • Asraf Atb
        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
        by Asraf Atb
        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
        01-27-2025, 05:02 PM
