55LV5500 has slight vertical lines
  • BadCapsTx
    • Jul 2012
    • 8
    They say a picture is worth 1,000 words. That is the best way to describe what my issue is. These lines appear to the right of higher contrast areas of the picture.
    Everything else on this set is 100% operational. I have changed the TCon with no effect. The ribbon cables from the Main Board and the TCon have been cleaned, again with no change to the picture quality. While the picture I have attached is a built in Menu system, the same issue occurs on OTA and HDMI inputs.
    Any ideas???
    Thanks in advance - Peter
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: 55LV5500 has slight vertical lines
    I'd guess BGA soldering issues... Do you have freeze spray?
    A working TV? How boring!
    • BadCapsTx
      • Jul 2012
      • 8
      Nope, all out but a good excuse to restock and try it!
      I'm assuming you are suggesting the main BGA under the big heat sink on the Main Board?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Yes, and that would be the main CPU. This certainly looks like it could be at fault.
        • frannyjunk
          • Oct 2010
          • 82
          Did you solve the problem?
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • hendue
            BenQ 2765HT vertical lines, no picture
            by hendue
            I was trying to fix the monitor, which was giving me the following pictures:
            It was somehow reactive, such that if I pressed the buttons, the lines changed in positions or if i moved e.g. a task window, it would somehow change the patter, too.
            I swapped out the mainboard without any luck. So I thought that it has to be an issue with the panel itself and was trying to assess whats wrong on the control board of the panel.
            Somehow, I managed to short the LVDS protection with a MOSFETS cooler on the PCB.
            I turned around...
            09-09-2025, 08:27 AM
          • srs
            Insignia NS-50DR620NA18 w/ large vertical lines & no picture
            by srs
            I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
            A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
            I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables...
            04-22-2023, 02:40 PM
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
