Source for LG LGE5532 BGA
  • midnightg35x
    • Apr 2013
    • 58
    Are there any reasonable sources for the LG LGE5532 XD Engine BGA? I know ali express lists them, but that's a crap shoot. I'm working on an LG 65UF6450 that most likely has a bad BGA. I can't find a replacement mainboard EBT64049103 at all either. I have access to suitable equipment to do the work.
    Side note: I haven't had to get replacement boards in awhile and it seems like almost everything is sold out these days.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Source for LG LGE5532 BGA
    If it has a bad BGA just replace the balls, unless you mean bad chip. Then it's either Ali or a scrap board.
    • midnightg35x
      • Apr 2013
      • 58
      It was the product of what I told was a lightning strike, so I'm guessing it is the entire chip. When I say BGA, I assume that means the entire chip, not just a reball. I don't get the BL_ON signal to ever go high so the backlights never fire, although PS_ON does work. Using a flashlight I can see colored snow on the right side, blank on the other. I never can see a menu and there is no sound. Disconnecting TCON ribbons gives me the expected white screens. I liked it a lot better when manufacturers used separate HDMI switches and you could generally just replace those alone without blowing the main IC.
      I don't keep enough stock of TV's to keep scrap boards around, and sadly it seems that finding replacement mainboards is like striking gold. Guess I'll be rolling the dice on aliexpress.
      • diif
        • Feb 2014
        • 6978
        • England
        BGA stands for ball grid array, the solder balls on the bottom of the chip.
        Doing a search for LGE5532 gives only this page as a result, is there a typo ?
        • midnightg35x
          • Apr 2013
          • 58
          I understand BGA is ball grid array as a land pattern. Probably a product of my work. If I say to someone, go replace the BGA, and we only have one on a specific board (like and FPGA or something similar), it is implied I guess what is meant.
          Yes I did have a fast finger typo. Looking at the LGE 5332.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Ask Suny from SEE-IC, I think they have it in stock.
            A working TV? How boring!
            • midnightg35x
              • Apr 2013
              • 58
              I just checked their website and ebay page, I don't see the LGE5332
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                Ask Suny directly on Skype: suny_chips. Their website is not updated regularly and they have higher prices on ebay to cover ebay's commission. I've been dealing with her for over 6 years and she's by far the best sales rep I've ever talked to.
                • Lvsitano
                  Asus X532FL 3.2V at source and gate
                  by Lvsitano
                  I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
                  First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
                  I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
                  First...
                  06-26-2024, 02:13 PM
                • tofik
                  MOSFET equivalent K8A60DA
                  by tofik
                  Hello guys,
                  I have a shorted MOSFET K8A60DA with the following characteristics:
                  Type Designator: TK8A60DA
                  Marking Code: K8A60DA
                  Type of Transistor: MOSFET
                  Type of Control Channel: N -Channel
                  Maximum Power Dissipation (Pd): 45 W
                  Maximum Drain-Source Voltage |Vds|: 600 V
                  Maximum Gate-Source Voltage |Vgs|: 30 V
                  Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                  Maximum Drain Current |Id|: 7.5 A
                  Maximum Junction Temperature (Tj): 150 °C
                  Total Gate Charge (Qg): 20 nC
                  Rise Time (tr): 25 nS
                  Drain-Source
                  07-19-2023, 05:18 AM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • the_rem
                  Unknown transformer : how to find a good replacement part ?
                  by the_rem
                  Hello guys,
                  I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                  I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                  04-23-2025, 01:48 AM
                • shovenose
                  Source for quality stumpy 450v/150uF STGCON cap replacement
                  by shovenose
                  I am attempted to replace this capacitor to repair a power supply. I put in a random used NCC KXG 450v/100uF and it worked but it's too tall and skinny to reinstall the heatsink and even if I drill a big hole in the heatsink for the cap it would still be too tall and the power supply will no longer fit in the network switch.
                  The original cap seems to be 35mm in diameter and maybe 25mm in height. I could probably go up to 30mm in height and be OK.
                  Thanks for any help with a source for these, I only need one or two, and the cheaper the better. I found some on eBay that...
                  08-17-2021, 10:47 AM
