PS51F8500 BN44-00619A power supply thermistor failure - but what else?
  • T.F.
    • Aug 2021
    • 4
    Hello!
    I was watching TV recently when it shut down while tripping the circuit
    breaker. A couple of days later I removed the back panel, and, looking
    at the PS module, I discovered a broken component, a thermistor. A bit
    of it had split off and this fell into my hand while taking off the panel (see
    photo, it's directly to the right hand side of that metal casing with the plug).
    I'm not an expert by any means but I do think I can manage replacing it.
    Question is, though, is this likely to be the entire issue, or will there be other
    defective components which led to the thermistor breaking in the first place?
    What do you recommend I should be looking at (and how)? The two fuses are
    both fine.
    Looking at similar such issues elsewhere as well as on YT it seems that the
    FETs are a frequent cause of failure.
    Decent multimeter and soldering equipment are on hand.
    Thanks very much indeed for any assistance!
    T.
    Here's a stock photo:
  • R_J
    • 9549
    Re: PS51F8500 BN44-00619A power supply thermistor failure - but what else?
    The thermistor went because the relay contacts are bad, sometimes you can get away with cleaning the contacts, but it's best to replace the relay.
    Current flows through the thermistor in standby, but when the tv turns ON the relay shorts the thermistor.
    • T.F.
      • Aug 2021
      • 4
      Thanks for the quick reply! Do you suppose that would solve it? Are there any other components I should be looking at (such as the FETs, which seem to be prone to failure and always included in "repair kits" I've seen on various sites?)?
      T.
      • R_J
        • 9549
        Usually if the fets are shorted, the DC fuse will be blown. The ntc goes open because without the relay shorting it when the tv is ON, ALL the current is running through the ntc and it will eventually burn up and open.
        • T.F.
          • Aug 2021
          • 4
          Thanks for the help R_J. Besides having been busy looking for a
          replacement TV, I've also been looking to procure those parts,
          and it's quite difficult indeed. Apparently there's no local electronic
          shops *at all* and there's no alternative to ordering them from China,
          at least the relay (NTC seems to be available closer by).
          What might likely happen if I were to (temporarily) replace the NTC only?
          And what about (removing and) cleaning the relay contacts, as you say?
          Could that be a temporary workaround?
          Just out of curiousity, what would happen if you used a 13mm NTC instead
          of a 15mm one (still 8 Ohms/5A)?
          Thanks again!
          • R_J
            • 9549
            The smaller ntc will handle a bit less power but should not be an issue, Try cleaning the relay contacts, that should be ok, If you only replace the thermistor and the relay contacts are bad, when the tv is on and operating at full power, ALL the current will be passing through the thermistor and it will not handle it and it will burn up and open.
            • Silidagreat
              • Jul 2023
              I have the same problem with this board. Does anyone know what is the part number for that thermistor or does anyone have the diagram for this power board?
              Please?
              • R_J
                • 9549
                An SCK-056 (4.7Ω, 6A, 15mm) should work, If nothing else is bad I would suspect the relay contacts are bad and not shorting out the nt801s when the power supply is ON. (not in standby)
                  DVR camera recorder switching power supply capacitor failure really
                  by sam_sam_sam
                  These cheap non brand capacitors at it again
                  Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                  Well at least I have the cameras back on line I to try the...
                  01-22-2022, 06:28 PM
                  Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                  by sam_sam_sam
                  I was working on this CNC machine today found no keyboard functioning no control relay powering on
                  The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                  Found shorted diodes on main controller relays there are 3 of them that...
                  01-07-2023, 05:43 PM
                • shovenose
                  Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
                  by shovenose
                  Got this one for free because, well, it no worky.
                  A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
                  Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
                  08-11-2021, 01:26 PM
                  DVR recorder Switching power supply Failure
                  by sam_sam_sam
                  When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                  Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                  This...
                  05-27-2023, 03:03 AM
