Hi, my tv works fine apart from the backlight which I found was due to a couple of blown Fet's that I haven't yet replaced however I have no 5v on my POK pin, is this normal? I found a schematic for my power supply and it seems that IC701 generates the voltage on it's VREF pin, after measuring this pin it seems to be working fine as I see a steady 5vdc output, the reason that this voltage is not getting delivered to the pin is due to a 7.5kohm resistor between the IC and the pin. (schematic below) any ideas as to what's going on? maybe my tv's motherboard doesn't require a POK signal? Thanks
No Voltage on POK pin Philips 42pfl6007h/12
Re: No Voltage on POK pin Philips 42pfl6007h/12
If you still have the blown fets then the backlights will not be working (as you say) so there may well be no UC1' to supply ZD702.
I would check again when the mosfets have been replaced.Willing to help but I'm no expert. -
Whar values are R719 and R720
What resistor number on the circuit are you refering to as the 7.5K resistor
If Q702 is not installed then you should have some votage at POK. There's a resistive divider R719 and R720 reducing the Vref voltage down to provide the POK voltageLast edited by dick_barton; 08-08-2021, 08:36 AM.Willing to help but I'm no expert.Comment
Is your set up and running now?Willing to help but I'm no expert.Comment
by Bad_IC
I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
These are the voltages in some pins of IC fsq510:
Vcc=18v
D=320v
Vstr=154v
Unfortunately, I couldn't find the schematic
What else could I check?
Is it possible to provide standby voltage from an external source to allow the TV to turn on?
Thank you​... -
i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
VCCIO voltage ok
VCCSA Voltage OK
VCCPLL Voltage OK
Ram Voltage ok
RamVTT OK
VPP 2.5 OK
But No Core Voltage
and i want to this vrm ic datasheet or pinout (ISL69269)
anyone have this ic pinout voltages?...06-25-2025, 07:19 AM -
by GabrielThis tv had a blow C9145 1KV capacitor and a U9101 3S121 on the back that reached ~70C within a few seconds after connecting to 230V.
I replaced C9145 with a similar type cap and ordered a 3S121 on aliexpress and the chip now is at 30C but vcc on 3S121 goes up to 14v dc and down to 8v and up again.
I did check Q9109 K13A65U in a transistor tester, I think it is fine.
I can't seem to find other faults on this board, what is blown since the voltage is going up and down ?
My psu is a 715G7831-P01 and I found a service manual that has almost... -
by electron_jjHi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
I have been inspecting and testing the capacitors and diodes in the power supply board to try to... -
by sam_sam_samI found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
Now... - Loading...
