Panasonic TX-58AX802B - Boot Freeze
  • Shotgun25
    • Feb 2014
    • 90
    I have a Panasonic TV a friend gave me which I wanted to get running again.
    Seems the firmware might be corrupt because it will boot to the logo and then freeze and boot loop.
    I have tried to use a USB recovery flash following Panasonic website instructions, but no progress. If someone has other recovery methods I'm open to advice.
    I was told the problem got worse over a period of time until it wasn't booting.
    I believe this model uses eMMC for firmware storage which from my experience with android tablet is usually a short lifespan storage technology.
    My questions.
    1. Does anyone have the full firmware dump for this TV set?
    2. What programming adapter have people used to program this?
    I have an RT809H external programmer and I believe I could get a replacement eMMC chip from somewhere, but the programming of the firmware is my concern. I'd rather have some firmware to flash before ordering adapters and chips.
    The panasonic firmware I downloaded was named "P143_3130.zip" which contained file "SDDL.SEC".
    I'm not sure if that would be suitable to be flashed to a fresh eMMC chip, I would have assumed it needs unpacking?
    Or would putting an empty fresh eMMC chip on the board and trying the recovery procedure again likely succeed?
    Any help it welcomed.
    Thanks!
  • Shotgun25
    • Feb 2014
    • 90
    Re: Panasonic TX-58AX802B - Boot Freeze
    Bump.
    I saw this thread a few months ago when I did some searching, but seems the users only ever managed to get a IC1600 Winbond chip, not the IC8903 eMMC contents.
    https://www.badcaps.net/forum/showthread.php?t=77395
    Hoped someone would have been able to grab the contents either via programmer or a method of dumping to USB via a script like some Vestel boards are capable of it if enough of a working state.
    Any assistance would be appreciated.
    • nomoresonys
      • 12328
      • U.S.
      Originally posted by nickterence2
      This guy repair panasonic tx-50ax802b, tx-58ax802b and tx-65ax802b. Ge received mainboard all over the world. Just buy the service and send him your mainboard.
      https://www.ebay.co.uk/itm/354245249...mis&media=COPY
      Get out of here with this SPAM BULLSHIT.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4536
        • Italy - Milan
        i can't read all the link, i can only say you can'write the update file on a new chip, that is not the entire firmware, is only a patch or something like.. if you are interested i can try to help you remotely but we must contact in pm.. but i need a complete dump of current memory to be processed.. how can you do it? It is possible an inline reading without removing chip but you must search the web for the solder points..
        • maleksa
          Yamaha MOX8 boot freeze and distorted sound
          by maleksa
          My Yamaha MOX8 synthesizer recently developed two issues.
          Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
          Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
          11-07-2024, 03:28 AM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • privato89
          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
          by privato89
          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
          Let's begin:
          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
          03-26-2024, 06:37 AM
        • l3emarsh
          Firmware needed for A Panasonic TX-55FX555B 4K HDR TV
          by l3emarsh
          I have a Panasonc/vestel 55" 4K HDR TV and I need A copy of the Firmware.
          I replaced the main board and someone gave me a 43" FINLUX firmware as it is a Panasonic Vestel version, it got the TV working again but the PIP will not work, I can only assume that it's because the Firmware thinks it is 43" tv?
          I was greatfull for the TV to be workng again and it's been okay, but now I want to get it set up correctly.
          If anyone has a copy of the firmware I need PLEASE help me out and send me A copy.
          Greatfull for any help.
          01-11-2022, 07:44 PM
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
