Toshiba 32HL833G vertical lines, white panel
  • gentleman
    • Apr 2018
    • 19
    • Portugal
    Hi there,
    Got this Toshiba 32HL833G that when it turns on, appear black panel whit vertical lines.
    No menu, no image.
    By pressing the keys menu, input, p+, etc... it change until get white panel.
    Like in the photos.
    Is it the panel?
    I have already unplugged and connected all the cables to the boards.
  • gentleman
    • Apr 2018
    • 19
    • Portugal
    Re: Toshiba 32HL833G vertical lines, white panel
    I found on a website a photo of a 42" with the same symptom and the owner says that the defect was in the panel.
    • mmartell
      • Oct 2013
      • 3189
      Of course make sure your tcon ribbons are not pitted or burnt on the connecting pins and that they are seated properly.
      If you have access to the panel boards run your finger over them to feel for hot, shorted smd caps. You can also remove the bezel and inspect the panel-side ribbons to verify this area has no liquid damage.
      • gentleman
        • Apr 2018
        • 19
        • Portugal
        Thanks for your help
        I put my finger on the panel-side ribbons and all 6 are very hot.
        • gentleman
          • Apr 2018
          • 19
          • Portugal
          The T-con board is also very hot.
          • gentleman
            • Apr 2018
            • 19
            • Portugal
            Fixed.
            Clean the panel-side ribbons whit Isopropyl álcohol.
            Thank you for your help.
            • Anonmis
              Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
              by Anonmis
              Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
              The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
              12-01-2023, 04:31 PM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • brad2157
              Vizio E70-E3 Two white vertical lines
              by brad2157
              I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
              Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
              Replacement main board - Boots up fine, but starting...
              12-13-2021, 05:11 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
