Samsung LA40C530 LCD Backlight problem
  • provider10
    • Mar 2016
    • 52
    • South Africa
    Hi All
    Hope you can help . Got this Samsung LCD TV LA40C530
    Problem is with the backlights that intermittently switch off. They can be ok for more than 8hours, then next day only stay on for a few minutes.
    When they are off all voltages seem to be ok on Psu the BLu-on is OK.
    Any Ideas
    James
  • fanaticgames
    Samsung UE32D4010 Backlight problem, led ok
    by fanaticgames
    hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
    02-22-2023, 09:46 AM
    09-07-2024, 05:50 AM
  • sandinemail@hotmail.com
    Samsung BN44-00284A Backlight problem
    by sandinemail@hotmail.com
    Samsung BN44-00284A in a Samsung LE40B755 TV bought 2009.
    In November 2020 the TV didnยดt turn on only flashing red diod on front off TV.
    I then opened up the TV and found bulged capacitors on the inverter/powerboard.
    I changed all capacitors except the main two 450V 100uf capacitors.
    The TV has worked pefectly since.
    But this week it started to turn off the backlight. Audio on TV still works.
    Sometimes it turn off the backlight after 10 seconds but sometimes it works for hours.
    Any suggestions on what might...
    02-15-2023, 05:10 AM
  • sansanpartida
    Samsung QE82Q70RAT no backlight
    by sansanpartida
    Hi everyone!
    Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
    My issue: No backlight.
    Model: QE82Q70RAT
    Type No: QE82Q70RAT
    The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
    So hopefully, I can fix this cheaper.
    05-22-2024, 06:56 AM
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
