Hisense H50A6250UK
  • caveman11
    • Oct 2013
    • 22
    Hisense H50A6250UK
    Hi guys,
    Above TV has red standby led which goes out when turning on via remote or button.
    No backlights, no screen or response to remote thereafter. No apparent feint image visible.
    Replaced power board and main board with exact same issue pertaining. stby voltage rises to 2.7v upon power up attempt. 12v present. I couldn't detect power to the LED array.
    So, logic dictates:-
    I got a bad board with exact same fault.
    The TV recognises a backlight failure and stops dead.
    Something else I'm missing.
    Any help appreciated as always
  • caveman11
    • Oct 2013
    • 22
    Re: Hisense H50A6250UK
    ...from another post:-
    All done. Lo and behold it was a blown LED.
    If the remote had functioned I would have solved it in a fraction of the time...and wouldn't have bought spare parts.
    So, anyone out there with same TV....don't rule out an LED failure when the TV won't even power on.
    RDC55...I'm just doing this one as a favour. I'm not in the TV fixing game any more. Without your post, I'd still be wondering what on earth was going on. Many thanks.
    • Tecc1229
      • Jul 2017
      • 16
      While you were working with your tv before you found the issue, did your optical connection light up red, or was it off as well? I am having a similar issue, but haven't replace the main board yet.
      • edugimeno
        HiSense 55A7500F won't obbey to remote after power on
        by edugimeno
        Hi! I have this TV set that does the following:
        1) I press the red power button on the remote
        2) The TV turns on normally
        3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
        4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
        Then after it's off, it would again accept the TURN ON from the remote and same again
        BUT:
        -The remote does show the correct IR beam while observed thru a phone camera
        -The TV works fine while using the MiRemote...
        03-14-2023, 11:22 AM
      • Jackching
        Hisense 65R6107 remote sensor
        by Jackching
        Does anyone know if there is a repair for the remote sensors for these televisions? It only seems to work when it wants to. I tried a different remote and also tried factory resetting the TV. I find if i go close to the sensor that it'll work but outside 2 feet it wont.
        10-30-2023, 11:35 AM
      • cstout
        DeLonghi AC Remote only accepts 3V
        by cstout
        Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
        The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
        I can't find any schematics...
        06-03-2024, 03:53 PM
      • Mc_Millian
        Toshiba 50lf711u20 fire tv remote not pairing
        by Mc_Millian
        I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
        The Tv model number is: 50lf711u20 Rev B.
        I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
        I've tried 3 different remotes which should be fully compatible with this TV.
        Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
        The power button, along with the volume,back,select, and directional...
        04-07-2022, 12:15 PM
      • rustinjust
        Please help, where can I get a remote for my subwoofer?
        by rustinjust
        I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
        Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
        Is there...
        10-28-2023, 03:43 AM
