Sony Bravia blinking red 7 times after lightening KDL-55DL-55EX720
  • thesteve
    • Jun 2021
    • 27
    Hi. This is my second post. So far no signs of life on this message board.
    I have a Sony KDL-55EX720 that works beautifully. But after an incident involving lightening, the set will shut down after a minute or so and flash red 7 times.
    I have a donor main board to use to swap parts if necessary. I tried swapping the board completely, but so far have had limited success updating the firmware which turns out is mandatory.
    Before I try any risky surface mount soldering, I thought I'd ask for advice.
    Thanks.
    Steve
  • neilc6
    • Nov 2015
    • 1550
    Re: Sony Bravia blinking red 7 times after lightening KDL-55DL-55EX720
    You can find a service manual at Elektrotanya if you google. 5 blinks is panel/tcon. I would check for 12V on the tcon fuse. If not present, there may be a blown surface mount fuse on the main board which supplies the 12V. If you have 12V, then try powering up the TV with only one side connected at a time between the tcon and panel and see if one side displays an image/doesn't produce an error.
    • thesteve
      • Jun 2021
      • 27
      Thanks for your reply. I was thinking I was blacklisted or something.
      This is an artificial problem, I believe brought on by high static voltage near the HDMI section from the HDMI ground.
      The 7 blinks seems to be caused by the over temperature detection circuit. Maybe there's an easy way to disable this false logic signal? I have the full schematic which points to a 6 pin surface mount chip, "mm3285fnre." IC9008.
      • neilc6
        • Nov 2015
        • 1550
        Oops I looked at 5 blinks and not 7 blinks. There is a troubleshooting flowchart in the service manual.
        • thesteve
          • Jun 2021
          • 27
          Re: Sony Bravia blinking red 7 times after lightning KDL-55EX720
          Hi, yes, I should have mentioned it's for the thermal sensor. I think the tiny surface mount chip got fried by the lightning. I found the location on the board and the data sheet. Luckily it's located on the top side of the board so I can probe it for logic while it's on. Maybe I can just jumper it to stay happy (if the IC is the problem). Or I could swap it from my other BAT main board.
          • thesteve
            • Jun 2021
            • 27
            I found the problem.
            The thermal sensor is doing its job... the trouble is its neighbor, the HDMI port processor (ic5500) which gets so hot I burned my finger.
            This makes sense since the lightning that zapped my electronics came from the HDMI cable from my cable box.
            I remember now, that after restarting the TV after the lightning, the original HDMI port I was using no longer worked.
            Then the shut down problem began with the 7 red LEDs.
            Oh well, maybe I can put a mongo heat sink on the bad chip and hope only the shorted part burns itself out.
            Or maybe I can somehow isolate the pin(s) that are tied to the bad HDMI port.
            • androripara
              Sony Bravia 55HX820 - 4 times blinking red standby led
              by androripara
              i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
              I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
              Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
              10-19-2023, 05:16 AM
            • YasaCh
              Sony kdl 40p5500 red light keeps blinking 3 times
              by YasaCh
              Hello...
              my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
              i opened the back cover no sign of damage on the powery suply or motherboard
              when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
              another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
              07-07-2025, 11:53 AM
            • NolesFan
              Sony kd-85x85j LED blinking red 6 times
              by NolesFan
              I know the 6 blinks are a backlighting issue, but when I pulled off the back cover and turn it on, the is a white flash from with the panel then I hear what sounds like a relay trip and the TV goes into the 6 blinking light code. Before I pull all the electronics off and checking the individual strips, there is a on the power board, a harness with 4 wires that run thru the panel, which are what I believe are the LED lines, but Im not a tech so no clue. Wires read OUT 1 + & - and OUT 2 + & - My first inclination was to remove the power board and use my LED tester and go to each + &...
              03-16-2025, 11:50 AM
            • thstuff
              SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
              by thstuff
              This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
              Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
              1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
              2) Waited 30 seconds, then pressed remote Power button and "Select language"...
              01-30-2023, 05:01 PM
            • JUCaESAl
              Sony bravia KD-65AF9
              by JUCaESAl
              Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
              Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
              10-20-2025, 04:03 AM
