I refuse to give up ... (LG OLED65C7)
  • ThomasX
    • Jun 2021
    • 15
    • Sweden
    ... sooner or later someone will respond to one of my posts
    My LG OLED65C7 turned black and quiet. When turned on, it stayed on for 20 seconds and then shut down.
    I measured the power board voltages and signals, and the DRV_ON was 1.6 volts, but 24VT was 24V.
    Then i removed both the MB and the PB to inspect them.
    Put them back, and connected a USB mouse.
    Then the TV turns on, and does not shut off after 20 seconds, it stays on.
    And the DRV_ON is now 3.0V!
    I am confident there is no issue with the PB, all voltages seems ok.
    But the TV is still black and quiet.
    The DPC signal is 0V, and I have not been able to find out what it's for.
    The TV shows up on the wifi router, so it does connect. When I connect a USB hard drive, the TV apparently reads from it.
    So, it seems the MB is now working as it should, but I don't get any picture.
    Any suggestions on how to progress?
    Thanks!
  • ThomasX
    • Jun 2021
    • 15
    • Sweden
    Re: I refuse to give up ... (LG OLED65C7)
    Whoooopss!!!!!
    It turned out I had disconnected the TCON ribbon cables in both ends, and not re-connected them at the TCON side when I put the MB back.
    When I connect the TCON ribbon cables from the MB, I am back to the situation where the TV shuts off after 20 seconds. So that to me is a clear indication the problem is at the TCON or later.
    So now the question is, how do I remove the heat sink plate from the TCON in a good way, without damaging the IC that it is stuck onto?
    Thanks!
    • Maalobs
      • Jun 2016
      • 120
      • Sweden
      Post some pictures of the PCBs.
      See if the service manual that's downloadable from this page, covers your model:
      https://www.electronica-pt.com/esque...ileinfo/67106/
      The manual seems quite comprehensive, with a nice troubleshooting chapter.
      As for the heatsink, if it's the kind that is a stamped plate of aluminium and you have removed any screws from it, it's probably stuck with a double-sided adhesive tape on the main IC where there is a stamped pit in the plate.
      You can heat it up with a hot air station to help loosen it, but it's enough to simply start rotating the plate back and forth clockwise-counterclockwise on an axis around the pit where the adhesive is.
      Small movements, be very patient, and as you go on you notice that it's allowing you bigger and bigger movement until it pops off.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Is Vx1 as shown in the manual at 0V ?
        • ThomasX
          • Jun 2021
          • 15
          • Sweden
          Hi
          Thanks for your responses! Much appreciated!
          That service manual does not match my model nr precisely. But I have another one that does. However, strangely enough, the manual you link shows the VX1 in the correct position on my MB, while the manual I had before with the correct model nr, does not. Strange.
          The VX1 voltage is as follows
          Voltage across Resistor = 0 V
          Voltage on both sides of the resistor vs GND = 1.37 V
          It's unambiguous which voltages is ment.
          Thanks for the tip about the heat sink plate. It came off nicely and easily from the TCON, it's the MB that will be the tricky one. It got 4 connectors through the PCB, so wont allow twisting.
          I think the best lead I have now is the DRV_ON signal that shows the following behaviour
          DRV_ON = 1.6 volts when TCON-MB Ribbons connected, TV turns off after 20 seconds
          DRV_ON = 3.0 volts when TCON-MB Ribbons disconnected, TV stays on
          So I am assuming that the DRV_ON has a pullup on the MB, but is also connected with the TCON that for some reason pulls it down to 1.6 volts. I will search for the DRV_ON signal on the Ribbon connectors, and see if I can trace it into the TCON board.
          EDIT: Nope, no direct connection of DRV_ON to TCON.
          What does it mean that VX1 is locked? I understood that is a good thing.
          • ThomasX
            • Jun 2021
            • 15
            • Sweden
            Change the power board, they said
            Change the mother board, they said
            Change the TCON board, they said
            I would've been ruined
            I used what I had and changed C956 and F3.
            Cost zero €, it was all in my "goodie bag"
            And now the TV works again! YIHAAAAAA
            It was a capacitor on the TCON board that had shorted, which in turn led to Fuse F3 blew.
            Thanks for your support!
            Took what I had, car fuses works in TV's too
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              It would be useful if you would identify the capacitor in the event that someone at a later date may have the same problem.
              • ThomasX
                • Jun 2021
                • 15
                • Sweden
                Capacitor was C956, but it's more or less just a coincidence it was that particular one. It could've been any one of 20 or so caps in the power area of the TCON board.
                • petehall347
                  • Jan 2015
                  • 4450
                  • United Kingdom
                  10 amp fuse ?
                  • ThomasX
                    • Jun 2021
                    • 15
                    • Sweden
                    That's what it said on the board just text to the F3 fuse, 125V/10A
                    The 24VD voltage is 24V 15A from the power board, considering the size of the TV and the light power with an all white screen, I'm not at all suprised
                    I'm more suprised the capacitor didn't blow before the fuse did, though
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      I would suggest you change the fuse for the original type fitted which will have quite different properties to the automotive fuse.
                      • ThomasX
                        • Jun 2021
                        • 15
                        • Sweden
                        Yup, it's already on order
                        Will replace all those caps as well with new ones while I'm at it
                        I couldn't find any capacitors of the same package and value with a rating higher than 25V, which could explain the why it broke, as it's on the 24VD circuit.
                        I bet there's lot's of LG OLED TV's out there that got the TCON, and possibly more, boards replaced, just because a 5 cent capacitor shorted out.
                        Will replace mine for a higher voltage rating.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4541
                          • Italy - Milan
                          Capacitors must be low esr, not good idea for me to replace the working ones..
                          • Tom41
                            USB chargers that give more than 5V?
                            by Tom41
                            I recently bought a portable label printer with a USB port that allows you to charge the internal battery. It comes with a USB-A to Micro-USB cable, but no charging plug. A sticker next to the charging port says "Warning! Do not use adapter with voltage over 5V!"
                            Thing is, are there any USB chargers that give out more than 5V, and in what situation would that be used? Just to be on the safe side I used a multimeter to measure my chargers - one is giving out 5.11V, the other is giving out 4.9V. The warning sticker suggests the printer doesn't have any overvoltage protection...
                            11-15-2025, 08:18 AM
                          • Phuong_Vu
                            Please help me, Please give me the gigabyte Z87p d3 boardview diagram
                            by Phuong_Vu
                            I need boardview gigabyte Z87p d3 to repair
                            whoever has please give me thank you very much
                            09-13-2025, 12:41 AM
                          • diggitt
                            Radio, no stations, quiet static sound
                            by diggitt
                            I am repairing a DeWalt DC011 radio. I found that the secondary coil of the transformer had gone open circuit and the amplifier ic had shorted. I have replaced both but I can’t tune it in to a station and the static is very quiet. Any help is greatly appreciated. Thank you
                            04-14-2025, 05:06 AM
                          • Rhaverz
                            Asus rog strix rtx 2060s a8g graphics card turns on and does not give video
                            by Rhaverz
                            Good afternoon friends, I have the same problem, the equipment turns on, when I connect it to the equipment and without connecting it to the HDMI or Display port with the integrated graphics of my equipment, the graphics can be displayed in the device manager with an error 43 but even if I try to update it "manually" it manages to remove the notice but it still doesn't work.
                            If I connect the graphic with the HDMI or Display port, the equipment turns on but it makes a long and 3 short beeps and does not give video
                            I thought that the BFDJ USB-C or MP8858GQ...
                            02-07-2023, 04:26 PM
                          • questore
                            HP OMEN 15-ce012nh give error code 5long 3 short after CPU LOW SIDE MOSFET BURN
                            by questore
                            Hello everyone.
                            Someone brought this poor hp in.
                            All power rails had normal resistances so i turned it on. Instant power cutoff...
                            First mosfet was shorted so replaced it...
                            After that I have tryed to start since no short was on the main power rail. the CPU middle dual mosfet heated up and protection shut down the laptop.
                            After investigating i have found that when the mosftet turning on then the mostfet got instantly hot (not the CPU)
                            Removed the faulty mosfet. -> now laptop turns on CPU mildly gets hot but laptop gives the common 5 long 3 short LED...
                            08-25-2025, 10:09 AM
