Samsung QLED Q60R constant reboot issue
  • Storyteller12
    replied
    I’ve seen the tape method work for years but as you mentioned the picture is usually degraded in some way or another.
  • edugimeno
    replied
    Originally posted by jason123
    It does sound like a similar problem. IF it's a diode packe issue, the shorted diode pack gets very hot (be careful not to burn your fingers!), At least it did in my case. You could do some voltage measurements on the PS rails first, just to be sure. Good luck
    Ok will check this next weekend. I've also seen that these tvs usually fail due to shorts inside the panel which is not repairable but the tape masking might take it back to life with some quality loss...
    Anyone know if this method would last or would only give a couple.months? Because that's what I've read...
    Will keep you all posted when I try it
  • jason123
    replied
  • edugimeno
    replied
    Hi everyone!
    I just bought an "as is" Samsung QE50Q60 Smart TV, it wants to start, lights up BL, but enters into a reboot cycle not even getting to show anything on screen.
    Should I start by going straight to these diode bridges? Sounds like it could be the same?
    Thanks a lot!
  • jason123
    replied
    Confirming that uClamp 6514P works fine to replace the defective IC. ESD7004 (non-bidirectional) DOES NOT work.
    replied
    I guess the 6514P is bidirectional and the one I used is unidirectional? Can't think of why else it wouldn't have worked. Can't imagine they just added clamping diodes just because. The fact they failed, tells me these are taking heavy hits, so running without them may not be very smart - I'm guessing Click image for larger version
    Good question, I too would like to know if these need to be replaced for safety or are they just redundant components. They fail a LOT, is it poor design? guess I also wonder if maybe they know these will fail just out of warranty and people will buy a new tv?
  • jason123
    replied
    Originally posted by lotas
    Datasheet for 6514P.
  • lotas
    replied
  • lotas
    replied
    Do you have a part number for these diode pack anybody? I removed the D002, the TV was working fine then I installed the OnSemi ESD7004, someone recommended on a different post, and now the TV is rebooting ago, though the pack is not getting hot.
    We removed it and there is no need to install anything else, everything will work fine, these diodes do more harm than good.
  • jason123
    replied
    I used OnSemi part SZESD7004 and that Did not work. I guess the 6514p seems to have an additional diode on the 3,8 pins.. maybe that's the difference? Anyway I have those on order, just now sure why the OnSemi parts didn't work.
  • blikker8
    replied
    Re: Samsung QLED Q60R constant reboot issue
    Hi. My tv (QN55Q60RAF) has the same rebooting issue. The cluster of diodes that contains D001 is extremely hot on the left side of the LCD panel.
    I am inexperienced in soldering and removing components - what kind of equipment would I need to attempt removal? And are there any tutorials out there that could help me? I've images of the hot cluster below. Thanks!
    https://cdn.discordapp.com/attachmen...5e646fe34722a&
    https://media.discordapp.net/attachm...446&height=438
  • S14Sr20det
    replied
    I had the same issue and also repaired by replacing with 6514p from Digikey on a Samsung. I have since repaired another tv (nec 55”) by simply removing both of the esd diodes and NOT putting any back in their place. I use heat tape on the cof cable strip and a terry cloth damped with isopropyl under the strip to soak heat and avoid lifting the pressed and glued strip. Then generous amount of flux and chip quick solder to knock them off then follow with iso then more flux and desolder wick to clean up remaining solder. Many TVs don't seem to have these diodes and the newer ones that do have them tend to fail easily.
  • Mordecai253
    replied
    Originally posted by jneupauer@sbcglobal.net
    this QN55Q60RAFXZA was rebooting.
    backlights stayed on when power cable to main was disconnected.
    i reconnected the cable.
    pulled ldvs cables... set stayed on.
    turned up volume... had sound.
    remote turned the set on and off normally.
    tried each ldvs cable one at a time... set stayed on.
    reconnected both ldvs.. set reboots.
    i removed panel circuit board cover and let it run with both ldvs cables connected.
    felt around the boards until i burnt my finger.
    found diode pack hot.
    removed two hot diode packs.. restored the tv to a working state.
    they are very tiny
    This saved me a lot of time. I got a set for peanuts from a fellow who had given up on a QN65Q60R that was boot looping. He had attempted to block traces on the LVDS cables and had concluded there was a short on the board. With the help of a infrared thermometer and temp probe I was able to identify a single 6514P ESR protection diode. third in from the left edge. I did a bit of a hatchet job trying to remove it but as soon as I was done I plugged it back in and the TV turned on and stayed on with the full image restored, no lines, artifacts, etc.
    Save for a 'water spot' near where I was working in the lower left corner. It might be flux (yeah, I know) or simply IPA I was using to clean. The use of an air compressor to dry probably exacerbated things, pushing the material up the COF cable. (Frankly, I didn't even know fluid could travel, apparently along the inside, of those cables) I've tried to gently heat the panel from both sides and carefully apply some negative pressure by shop vac - so far without any luck. The spot might just be getting smaller on its own but it's only been a few days. If any one has any advice on how I might ameliorate my blotch, I'd appreciate it. Otherwise, thanks a million for this thread. It was a marvelously simply fix.
    One last question for y'all. What is the best explanation for this failure? It seems the diode failed in the open state with high resistance either direction versus a shorted diode. Was this simply a defective component or did it fail while actually protecting data lines from ESD, power surge etc.? It won't be an easy component to solder back in place and I guess I'd like some peace of mind if I decline an attempt. Thanks!
    Note the blotch changes tone with viewing angle / pics taken at same time
  • pobrklija
    replied
    Just wanted to say that i had the same problem. Diode d001 is shorted in the right part of screen. I removed it and tv is working fine. Thank you
  • Pooshoes
    replied
    I had the same issue with my set, 55" QN55Q6DRAFXZC. It would show the samsung logo and reboot. In my experience with bad panels if the LCD had an internal short usually it wouldn't display a logo so i suspected something else was up. I whipped out the thermal camera and discovered d001 was getting toasty (140c+) and under the microscope you could see factory flux black and bubling out from under the chip. Simply knocked off the diode pack with a blob of solder on my iron and TV is back to 100%.
    Diode number is 4262H
    replied
    probably those diode packs, could try the method in post #15, maybe someone can verify HOW warm the diode packs get on a normal functioning tv.
  • Dennistech28
    replied
    Hi any resolve to this issue. I have the exact QLED Q60R TV. the same area gets warm when both lower boards are connected, when either one side or the other is connected the back lighting stay on and the area stays cool. like an over load with both connected.
  • Gawrion
    replied
    Hey! I got exactly the same weird issue with my QLED. Tommorow i will check if my diodes are gettin hot. Did You left Your set without or did U replace them with new ones? Is Your TV working fine now?
    replied
    Good to hear, with the tape cutoff method working, I wonder if you could put those chips back in place, some report that they are needed, I'm not sure, haven't run across this issue myself??
  • skaja
    replied
    I managed to resolve the ‘fixed horizontal lines’ by putting a half inch piece of tape on part of the panel led ribbon. This video helped me although it’s not exactly the same issue. Good luck future readers.
    https://youtu.be/XCJAx92JwPs
    Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
    This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
    09-07-2024, 12:10 AM
  • x_orange90_x
    Samsung UN50KU6300F constant reboot, bad backlights?
    by x_orange90_x
    This TV is in a constant reboot where the screen very dimly lights up for about 2 seconds and says SMART TV. I checked the power supply and visually all components look good. I unplugged the main board to see if the backlights would come on but they do not. I also tried my LED tester on the backlight plug and didn't get anything. I know some Samsungs will not light off a single led is out regardless of using a tester, so I'm thinking they are bad. I found a whole set for about $25 which isn't bad, but before I buy them is like to know if they would indeed cause a constant reboot like this tv is...
    02-09-2024, 08:41 PM
    09-07-2024, 05:50 AM
  • Kaar3l
    Samsung QLED QE65Q7FNAT only standby light
    by Kaar3l
    TV: Samsung QLED QE65Q7FNAT
    PSU: BN4400940A
    MB: BN94-12832K
    I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
    09-24-2024, 01:35 PM
  • brkie
    Samsung UE75TU6905 reboot loop
    by brkie
    I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
    I read on Samsung's website (reviews)...
    09-04-2024, 01:45 AM
