Samsung QE55Q7F Main board question
  • Smokie365
    • May 2021
    • 13
    • Ireland
    I'm looking to replace the main board on the above tv as it got damaged.
    The original part number on the board is BN94-11487J but this board seems to discontinued and replaced with BN94-12660J
    I have found some on eBay that look like it's front the 65” version but the part number ends in a D instead of a J
    Has anyone any experience with these boards and are they all the same really?
    So the board I am looking at is BN94-12660D
    Any help appreciated
  • Smokie365
    • May 2021
    • 13
    • Ireland
    Re: Samsung QE55Q7F Main board question
    Anyone??
    • R_J
      • Jun 2012
      • 9624
      I looked at pictures of both boards and they do look different, CN1105, CN1102, CN1104, also other parts are not used on the 11487 but are installed on the 12660, these plugs/transistors etc. are not used on the 55" there are may other differences as well? The 12660 "might" work for the 55" but the 11487 would not work for the 65"
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Have a look on Shopjimmy and see if they suggest compatible replacements.
        https://www.shopjimmy.com/samsung-bn...qn55q7fdmfxza/
        • Smokie365
          • May 2021
          • 13
          • Ireland
          Cheers lads.
          • Asraf Atb
            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
            by Asraf Atb
            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
            01-27-2025, 05:02 PM
          • mrautom8
            Samsung TV UN75H6350AFXZC main board schematics?
            by mrautom8
            Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
            Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
            While relay is on, all voltage rails are present and steady (scoped) on main board.
            I love a good logic puzzle but getting lost without any schematics.
            No shorts on ANY capacitor main board.
            Thermal camera shows 3.3V inductor getting warm instantly but...
            10-19-2025, 06:32 PM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • Lee M.
            Samsung UN75RU8000FXZA bad main board?
            by Lee M.
            When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
            11-08-2023, 07:46 PM
