Samsung-UN39FH5000FXZA-Will Not Turn ON
  • cherokee.warrior
    • May 2017
    • 87
    I have tried all that was listed on the following link
    https://www.badcaps.net/forum/showth...un39fh5000fxza
    the reading i get on cnm803 connector on the power supply are as follows:
    b13v 12.9v
    b13v 12.9v
    vamp 12.9v
    vamp 12.9v
    gnd 0
    b5v 5.3v
    b5v 5.3v
    pwm_dm 3.2v
    b13v 12.9v
    blu on/off 2.9v
    gnd 0
    gnd 0
    a5v 5.3v
    pwr on/off 2.3v
    If i completely take the connector running to the main board off the leds will come on. If i leave the main board connected and disconnect the tcon board the led lights will not come on. If i take the bl wire loose the backlights will not come on. im getting no sound, no picture, no backlights accept when the cable from the pwr supply to mainboard is disconnected and no standby light if this tv has one.
    I have replace ic 901 on th main board from shopjimmy and it had no effect. I started checking for shorts to ground and found some. They are show in one of the pictures i have posted. the arrows point out all the caps and im sure other items that had ground readings on both sides. I found the ic i replaced had some connections to ground that i don't think there should be.
    Is there a service manual to be had for this tv or some schematics of the main board so at least i can know the values of what might need to be replaced.
  • alfatv
    • Sep 2020
    • 353
    Re: Samsung-UN39FH5000FXZA-Will Not Turn ON
    I know, we all here like to fix things, but it may be less hassle to get used board on eBay.
    • neilc6
      • Nov 2015
      • 1550
      Very difficult to repair main boards especially since schematics are typically not available. I have never seen a Samsung main board schematic, only Philips or Sonys from service manuals online. Your PS voltages all look correct. TV not turning on could be EEPROM but you replaced that already. Other than that, you can check any on board regulators. Caps may be used for filtering so you can remove if you find them shorted but there are likely many on the same power rail and it may take time to isolate the correct one.
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • JDC
        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
        by JDC
        ONN 100012588
        Issue: No Power, Then Rebooting After Main Board Change
        Short answer: replace main board and power board
        Technical answer: replace main board and Q306 & Q307 on power board.
        Long answer:
        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
