Sony KDL55W800C Lines Across panel
  • Hwciua4i
    • Jun 2021
    • US
    I have a Sony KDL55W800C which suddenly started showing horizontal lines moving up and down the screen. Initially, it would return to normal after a while but then it stayed for a few days.
    I have now replaced the mainboard and the T-Con panel on the unit and the issue persists.
    Any help on troubleshooting and getting the TV back to regular working condition would be greatly appreciated.
    Thank you!
  • neilc6
    • Nov 2015
    • 1550
    Re: Sony KDL55W800C Lines Across panel
    Horizontal lines are bad panels. However, if you have a tcon board, you may be able to repair it with the tape cutoff method.
    https://techhometravel.com/repair-of...lines-on-a-tv/
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Raulnn
      Sony KDL-50W685A horizontal black lines Pattern
      by Raulnn
      good morning! I have a problem with this Sony. The image has a pattern of black horizontal lines, I attach a photo of the lines. The power supply is external and emits a sound. I don't think it's because of that. Let's see if someone can help me.
      12-10-2023, 06:50 AM
    • dvu0627
      Sony XBR65X900H TV with Horizontal Lines right half of screen
      by dvu0627
      I have a Sony Smart TV XBR65X900H that started to have horizontal lines on the right side of the screen (see attached picture). When I played video on Youtube green horizontal line at regular intervals(1/4") across the screen.
      I replaced the T-Con board but the lines are still there.
      I believe this issue is from the Main Board. Before I replace the Main board, I wanted to seek advise if this is the problem from the Main board or something else?
      Thank you for the help....
      02-05-2023, 03:39 PM
    • iglitare
      by iglitare
      09-04-2025, 07:13 AM
    • learnmore
      Samsung UE70TU7020K Which lines to tape on a bad panel
      by learnmore
      Hello Community,
      I'm working on a Samsung UE70TU7020K.
      It looks like a bad panel. There is only 1 FPC cable from the Tcon (built into mainboard) to the panel.
      I'm using a piece of tap a few mils (covers about 8-10 pins), at different locations and have had varying results but nothing that is remotely watchable (multiple lines across all the screen, half screen and total black out on screen). The buffer board is divided into 3 boards. I've disconnected the end board one at a time but each time the screen was totally black. I presume it's because the potential...
      03-15-2024, 03:01 PM
