Sylvania 42" Plasma TV
  • aliasdck
    • Sep 2009
    • 100
    Samsung Panel: S42SD-YD05
    Friend asked me to take a look at his 42" Plasma that had a couple of thin vertical lines on it.
    Attached is a picture of the display. I just wanted to get a professional opinion before I dive into this one - I am curious if this is likely panel failure or something fixable.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sylvania 42" Plasma TV
    My thoughts are it's either an X-driver or the control board. But that is REALLY only a guess. Wizard is the expert. The service manual for the panel is here:
    Registration is required, but free.
    PlainBill
    PS: The site is in Polish.
    pb
    • Wizard
      • Mar 2008
      • 2296
      Panel is junk. The thin vertical lines is terminal.
      Reason is: the vertical lines is driven by the Z drivers (at bottom or both top and bottom depending on panels) and these chips is bonded to the panel itself. Same thing with vertical band as well.
      If the lines or bands across, it is fixable by changing Y or the X driver (the board on left, most of time or right side)
      Cheers, Wizard
      • aliasdck
        • Sep 2009
        • 100
        Figured it was either a bad panel or a bad z driver or control board problem as plainbill was thinking.
        As usual, the expertise of wizard, plainbill and the like is a blessing here. Your guys advice throughout this forum is greatly appreciated.
        Thanks.
        • cadiman
          • Mar 2010
          • 397
          Who makes the pdp? Didn`t some of these drivers have solder problems for verticle line issues?
          • Wizard
            • Mar 2008
            • 2296
            No solder joints on Z-driver ICs. They are bonded to the panel itself.
            Cheers, Wizard
            • Krankshaft
              • Jan 2007
              • 2328
              Just to be clear by bonded you mean the die itself is soldered to the board and encased in that black epoxy blob we're so used to seeing right?
              • karusoo
                • Feb 2014
                • Estonia
                Hello I Have a Philips with panel s42sd-yd05 with Y board lj92-02016a.
                I saved it from going garbage about 2008 and replaced y board fets 5014 and 5015.
                It worked fine since to the end of the 2013. It had a flickering picture problem.
                Now I got disassembled: Power supply work fine checked the coltage the caps and looked ac rattle with scope on dc lines. All of mentioned are correct. Checked the Y board for caps or bad diodes of transistors, did not found any shorted.
                Whed I ran the panel with the dip switches in internal mode...the full white screen:
                The panel is like strobo...
                Is it the some IC from Y board?
                Best
                Alari
                • Stanley1843
                  by Stanley1843
                  06-29-2024, 11:54 AM
                • pni
                  LG 49uf695v vertical coloured lines
                  by pni
                  Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                  11-14-2025, 03:15 AM
                • afex
                  Samsung Plasma TV with vertical lines (model PN50B430P2D)
                  by afex
                  This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
                  This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
                  I have attached an image of the TV with these bars displaying....
                  11-08-2021, 09:23 PM
                • Falki
                  Colorful LCD Vertical Lines on Samsung ue55es8090
                  by Falki
                  Hello there, ive recently found an older 55inch Samsung SmartTV.
                  A similar issue has been posted as well but also with no actual response ...
                  08-12-2025, 04:19 AM
                • visionbluedemon
                  Help. Sony kd-65x85dj vertical lines
                  by visionbluedemon
                  First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                  Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                  tried blocking LC lines too, but same results
                  is it lcd panel issue or tcon board issue?...
                  07-25-2025, 04:56 AM
