Haier TV Not Turning On--Completely Dead with No standby light
  • djaywilly
    • May 2021
    • 7
    I have a Haier 50" LE50d3505b television that is "dead." No image, no standby lights, no sound, no nothing. The power supply board is HKL-500201A, and physical inspection looks good. I have tested the fuse (works) and the bridge rectifier (works). Also, the capacitors are not "puffy." However, a couple diodes seem to have faulty test results. I have tested diodes 10/11 using the "diode setting" on my multi-meter. I got .000 readings for both. For diodes 13/14, I got .177 for both readings. Do you think just these diodes are the issue? If so....would these be the correct diodes to replace them with: https://www.ebay.com/itm/11376729897...QAAOSwDw9bLDvU
    Or, should I just try to find a brand new power supply board, in case there are more parts that are an issue in addition to the diodes? If so....is this the correct board to use: https://partstore.encompass.com/item...er/6007460228/
    Thanks!
  • neilc6
    • Nov 2015
    • 1550
    Re: Haier TV Not Turning On--Completely Dead with No standby light
    Bad main board can make TV appear dead since the standby light is controlled by the main. You need to check if you have standby voltage going to the main.
    • djaywilly
      • May 2021
      • 7
      I meant to include this in the initial post. I am getting no 5V standby voltage to mainboard.
      • petehall347
        • Jan 2015
        • 4437
        • United Kingdom
        test diodes off the board
        • R_J
          • 9588
          You can save a lot of time by checking for voltages, Do you have the standby voltage going to the main board?
          Check JP1 for 5VSB
          • djaywilly
            • May 2021
            • 7
            R_J: I checked the DC voltages for JP1 5VSB. It jumps between 1.2 and 1.4V
            STB measured 0V
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Lift one end of each diode and if they still measure 0 ohms then replace them and then check if your voltages are present.
              • R_J
                • 9588
                Looks like D10 and or D11 are shorted, check them out of circuit, The 5VSB is likely low due to the shorted diode, The STP line is the power supply ON/OFF signal from the main board, without any standby voltage this line will be 0 volts.
                • djaywilly
                  • May 2021
                  • 7
                  So I am not experienced enough to solder. I also do not have the necessary equipment. I was thinking about just replacing the entire power supply board. Would this be the correct one to replace it with?
                  • piposarcade
                    Samsung UN50KU6300 dead no standby led
                    by piposarcade
                    01-04-2024, 01:33 PM
                    Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                    05-22-2024, 02:07 PM
                  • Dvsr
                    On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                    by Dvsr
                    Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                    I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                    After replacing the caps I started testing out the speaker. It seemed...
                    09-10-2025, 10:20 AM
                  • fharris1977
                    Vizio D50u-D1 Dead Set No Standby
                    by fharris1977
                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                    12-28-2023, 10:25 AM
                  • caspian
                    What Zener Diodes on a Linear Power Supply
                    by caspian
                    Dear members,
                    I have a linear variable power supply with unknown brand name that I used for voltage injection.
                    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                    In addition, I discovered that its zener diodes are defective.
                    I can replace the burned transistors.
                    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                    Therefore, I cannot replace the zener diodes.
                    I do not want to test the zener diodes in a test circuit to discover their model or value.
                    no schematics are available...
                    05-26-2025, 12:38 PM
                  • jacobtc
                    LG C1 65'' dead standby
                    by jacobtc
                    I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
                    If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
                    If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
                    I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
                    01-29-2025, 04:27 AM
