Sony KD-55X750F bricked, keeps rebooting
  • alfatv
    • Sep 2020
    • 353
    Somebody messed up with this TV before me.
    I got to the point where TV powers up, Sony logo appears, then animation, after that it powers down and all starts all over again.
    Tried vol- and power buttons, running circle appears for few sec, then same as above.
    Tried firmware update via USB, no reaction from TV.
    I know it's main board, but what else can be done?
    • 12331
    • U.S.
    Re: Sony KD-55X750F bricked, keeps rebooting
    Kit here, as always make sure it's a match if you get it: https://www.shopjimmy.com/sony-kd-55...air-parts-kit/
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4542
      • Italy - Milan
      Only operating system handlings, but you must know basics of linux/android shell environment, too long to explain, and huge amount of luck to avoid access protections.. which are the steps you made in this repair?
      • Diah
        • Feb 2013
        • 6607
        displaying the android animation mean the firmware which saved on NAND started, mean too bootloader / kernel started too. 2 reason could be for this reboot loop
        1- corrupted firmware ( same way you did the hard reset by power and volume- insert usb flash drive formatted fat32 and the last firmware on it from 11.11.2020 PKG format...and most important the usb flash drive must be with MBR mode) try it many time dont give up..
        2- bad sector on NAND ( Freez it to bypass the loop ) or bad BGA if some one work on it.
        • alfatv
          • Sep 2020
          • 353
          The first problem was with flex cable between main board and T-Con. Was not delivering power to T-Con. Added some scotch tape, good for now, will buy replacement cable once things are more clear.
          I didn't mess with file system, but not sure what was done before.
          Is there any way to hook up PC to this TV? Would be interesting to see at least boot log.
          • alfatv
            • Sep 2020
            • 353
            Diah, thanks for advice, take a look at screenshots and see if I done it right. Also, there 3 USB ports, any of these is OK?
            On #2, yes, it could be hardware problem too. The main board was not abused and I was the first one who removed heatsink, but few screws are missing, so somebody already looked at it.
            • Diah
              • Feb 2013
              • 6607
              i use always command at windows CMD if i have new usb flash to convert it to MBR,
              look here i wrote before how to
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4542
                • Italy - Milan
                TVs have always a serial port for debug, if you have schematics it's better so you can check if it is present on vga or hdmi port, but if not there is at least a not populated connector on the mb of 4 pins.
                • alfatv
                  • Sep 2020
                  • 353
                  I have a little bit of update.
                  Attempting update via USB didn't help, tried many times. I did format it as Diah suggested.
                  During boot-up the animation actually appears 2 times. After 1st attempt, the screen goes dark, then animation restarts again, but with brighter backlight.
                  Sometimes animation doesn't go through the process described above and stops in the middle, not always at the same point, but rebooting continues.
                  And couple of times the animation got stuck completely, had to unplug TV to restart it.
                  • Diah
                    • Feb 2013
                    • 6607
                    you have much likely having drooping /unstable voltage feed to mainboards. need to take look and run the PSU as stand alone to check all output voltage include BL section.
                    • alfatv
                      • Sep 2020
                      • 353
                      Yes, it's possible. I did check voltages with multimeter during the process and there was no much fluctuation. Also there are few regulators on mainboard for CPU and memories, they looked stable too.
                      Backlight brightness correlates with DIM signal from mainboard, so it seems to be OK. And BL_ERR stays close to zero, so there is no backlight error.
                      I will try to check voltages with a scope.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4542
                        • Italy - Milan
                        better to consult the log..
                        • alfatv
                          • Sep 2020
                          • 353
                          Still need to identify that port.
                          Take a look at pictures, is it RS-232C remote?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4542
                            • Italy - Milan
                            I've never done it on a Sony, maybe it is that connector but you have to check if prior it there is a level shifter IC like max232 or similar, to know the correct interface, or them are those 4 pins on the bottom of board right to that quartz and under the optical out, the pins to be used are the one visibly at gnd and the 2 center ones, that is a 3v serial
                            • Diah
                              • Feb 2013
                              • 6607
                              its so limited the UART, i am not sure you will get info to located the issue
                              however what i know and use
                              RS-232C are the TX RX for UART , the connection with audio stereo Jack as following
                              stereo Jack:
                              TIP = TV TX go to yours TTL RX adapter
                              RING = TV RX go to yours TTL TX adapter
                              SLEEVE = GND
                              Terminal Protocol:
                              Baud Rate: 9600 bps
                              Character Length: 8 bits
                              Parity: N/A
                              Start Bit: 1 bit
                              Stop Bit: 1 bit
                              Flow Control: N/A
                              • Carlos#2003%
                                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                by Carlos#2003%
                                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                02-15-2024, 07:52 PM
                              • dkneyle
                                Sony KDL-46HX850 Can't upgrade/update firmware
                                by dkneyle
                                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                09-25-2024, 10:44 PM
                                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 05:27 AM
                              • thesteve
                                Sony experts? 2nd bricked BAT Board after firmware update KDL-55EX720
                                by thesteve
                                So I bought another main board from eBay and the same thing happened.
                                I got the firmware file from the Sony website. My model was listed and everything matched.
                                sony_tvupdate_2011_4027_aaa_auth.zip was the file.
                                Extracted to a folder: "sony_dtv0FA10A01A0A1_00000301"
                                with file: 00000301_07e8046a.bin inside.
                                Loaded it into the root of an otherwise empty USB thumbnail bought from around the same time as the TV. Not too old, not too new.. under 2Gig.
                                The file reads perfectly. Lots of "disk activity"...
                                07-17-2021, 04:59 PM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
