lc-49cfg6021k logo loop
  • jesterace
    • Aug 2013
    • 87
    Got this TV that originally had the fault of being difficult to come on, i.e. stuck in red light standby. If it did come on, the light would go white but show no picture. Then after some time it would go back to red.
    Tested all PSU voltages. 5v, STB and 12v all present and look stable.
    Found a mainboard for 30quid so at that price it's not worth messing around. Fitted the used board which was supposedly working, and now it does show the sharp logo for about 30sec but then goes off and reboots showing the logo again.
    Would you still be ruling out the PSU? Old board wont show any image. This board does. After a few attempts to boot, it seems to give up. The red light then gives a slight blink every 10sec or so (hardly even noticeable but it does blink). Turning power off and back on allows sharp logo loop to begin again.
    Spoke to Sharp and got a copy of USB firmware. Put the files on FAT32 stick, but the TV doesn't attempt to read the stick. The stick blinks briefly for a split sec when the sharp logo comes on and then it doesn't attempt to read anymore. Not sure if there is a procedure I'm missing to kick off the firmware update or if this mainboard is also faulty to the point that it wont update.
    Any help appreciated!
    Thanks,
    James.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4460
    • Italy - Milan
    Re: lc-49cfg6021k logo loop
    Much probably an error in the flash file system, data losss etc prevent the software to fully load, this is particularily common on Android TV, if it is..
    • nomoresonys
      • 12276
      • U.S.
      Many times the boot loop is a faulty mainboard, I'd send it back and try a different one, just my best guess.
      • jesterace
        • Aug 2013
        • 87
        Ordered another board today. Hope it fixes it. I would have liked to have tried flashing the nand but I cant find a dump anywhere. If the 2nd board works i'll consider taking a dump of it! I'll update when the 2nd board arrives if it helps anyone.
        • ducky29
          • Dec 2015
          • 369
          • Europe
          You should have contacted the manufacturer instead of buying a new board. They will provide you a firmware for your tv that hopefully will fix it. Cancel the order if the seller has not shipped yet. http://www.umc-uk.co.uk/
          • nomoresonys
            • 12276
            • U.S.
            Could be a chip on the mainboard is faulty or corrupt...just a firmware update may not do the trick, won't know til you try tho.
            • Diah
              • Feb 2013
              • 6437
              could you show us high resolution focused photo of the original mainboards from both side ???
              BTW: to update sharp , you should have files with .bin and other with .txt format
              the file with .bin need to make copy of it and rename the copy for example:-
              you have "allupgrade_6486_aes.bin" make another copy to the same file under name "allupgrade_6486_aes_U.bin" with out ""
              so your USB flash drive will have 3 files the 2 above and one "UMC_KMODE.txt"
              use the USB slot on the side close to CI socket, while the set out from wall socket.
              • Takeatry
                Yet another Samsung QLED Boot Loop
                by Takeatry
                Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                10-04-2024, 02:57 PM
              • giova96
                samsung qe55q60rat logo loop
                by giova96
                Good morning
                I have this Samsung which has the typical display problem, basically I see the initial Samsung logo for a few moments and then restarts
                I have the audio from the antenna present, by disconnecting a flat panel from the display the TV remains on with the audio of the program present, but everything on the screen is black (backlighting present)
                I know that there are steps to save it by performing operations on the panel card
                Does anyone have a more detailed guide? given that this is already the 4th TV that this has happened to me and it seems like a fairly well-known...
                03-06-2024, 03:30 AM
              • Teban1306
                [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                by Teban1306
                Hello everyone!
                I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                System Information:
                • Model: Lenovo ThinkPad T14 Gen 1
                • Machine Type: 20S1S4E600 (Intel i7 variant)
                • Current BIOS: N2XET42W (1.33) - Latest version
                • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                What I'm trying to achieve:
                Replace the default "LENOVO" boot logo with a custom image during POST.
                🔧 What I've tried:
                09-14-2025, 11:49 AM
              • ahkh_72
                Surface Pro 5 Loop on logo
                by ahkh_72
                Hi
                there is surface pro 5 (1807)
                MB : M1011229-019 REV 4.3
                when i power it on , display logo for 3 second and power off.
                I know that the problem is with the BIOS file, because when I programmed this BIOS (https://www.badcaps.net/forum/showth...highlight=1807)
                ,the problem was solved, but it does not boot and the touch does not work.
                Can anyone fix the original bios I attached?
                Thankful...
                11-19-2023, 09:36 AM
              • gavenb
                Sharp LC-80LE661U 80 inch
                by gavenb
                Hi folks!
                I have a LC-80LE661U that had some interesting issues.
                Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                11-12-2023, 02:05 PM
