Telefunken D32F289M4CWI no picture Only the sound
  • samtron786
    • Aug 2016
    • 154
    • germany
    The problem with the Telefunken LCD TV "D32F289M4CWI" is that since switching from one program to the other, the picture is gone and only the sound can be heard (screen remains black).
    The TV is about 2 years old.
    Would still be grateful for help
    many thanks
  • nomoresonys
    • 12087
    • U.S.
    Re: Telefunken D32F289M4CWI no picture Only the sound
    (screen remains black) If you mean there's no backlight, check the screen by shining a flashlight on it, maybe at an angle, see if there's a picture or hit menu see if there's a display at all with flashlight.
    • samtron786
      • Aug 2016
      • 154
      • germany
      Yes I can take a picture with low light
      • samtron786
        • Aug 2016
        • 154
        • germany
        I tested the LED again, they are all fine
        • nomoresonys
          • 12087
          • U.S.
          Read and comprehend/translate post #2.
          • samtron786
            • Aug 2016
            • 154
            • germany
            Yes I only have sound, no picture and no obstruction lighting
            • nomoresonys
              • 12087
              • U.S.
              Check the fuse on the tcon board, meter 20 vdc black - probe on metal chassis ground, red + probe on each side of fuse see if it's about 12 volts on each side.
              • samtron786
                • Aug 2016
                • 154
                • germany
                Yes I have 12.20V in both sides
                a question, is there a list of VAVDD how much current has ??
                the diode has 3.33V
                many thanks
                • nomoresonys
                  • 12087
                  • U.S.
                  Some simple voltage testing there: https://www.youtube.com/watch?v=t11FEuu1oWU
                  • samtron786
                    • Aug 2016
                    • 154
                    • germany
                    gives wiring diagram of this TV ??
                    or do I have to look for wiring diagram from T-Con?
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • Ierwin
                      by Ierwin
                      05-13-2025, 03:31 PM
                    • jchang
                      Samsung UN70NU6900F no picture and no sound
                      by jchang
                      Hi all
                      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                      Symptom:
                      No picture no sound.
                      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                      No sound at all.
                      What I tried:
                      1. I tried unplugging the left or right ribbon...
                      01-09-2023, 06:28 PM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
