Samsung Plasma PN43D430A3DXZA
  • clearchris
    • Dec 2013
    • 687
    I'm starting to suspect that I have a bad power supply on this TV or a bad logic board, but I'd like to run it by you guys.
    TV is in unknown condition, knd of dirty.
    Screen has no sign of damage.
    Will display fuzz for a flash upon start.
    Clicks when turned on and when plugged in.
    No sound on start
    No picture on start
    Power supply voltages, PS_ON, standby, 5v and 15v lines all test ok on the bench, under no load. VA is at 56v and VS is at 206v, but I don't see the expected voltaged listed on the board anywhere. Again, no load.
    I ran the test here with the jumper on pins 3 and 4 and no test patterns (or anything else) were displayed.
    https://www.badcaps.net/forum/showth...461#post318461
    I checked the test points on the PS for VA and VS and voltage was half what it was on the bench, and going lower as I watched. I assume that was the capacitors discharging. This behavior was seen with the Y (and thus Z) boards plugged in and also with them unplugged.
    LED on the logic board has long blinks.
    Any ideas of what else I can test?
  • clearchris
    • Dec 2013
    • 687
    Re: Samsung Plasma PN43D430A3DXZA
    I hooked an external speaker up to the tuner board, still no sound. I put a tuner board and a logic board on order. Pretty cheap, under $20 for both, shipped. We'll see if that solves it. I'm not entirely convinced it's not the PS, but so far I have no direct evidence to support the bad PS hypothesis.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      So VS and VA stay up but no image when everything is connected in the TV ? If not check for low resistance across Ysustain VS to ground and also Xsustain VS to ground very common for transistor failures these are, make sure you disconnect the boards from each other though.
      • clearchris
        • Dec 2013
        • 687
        Kind of the opposite. I think that VS and VA turn or for a second or so, just enough to charge the caps, and then turn off. This happens with power connected to X and Y boards AND when power is not connected to X and Y boards. What I see when I measure VA and VS is that the voltage is around halfway of what it should be, and dropping, about 1v per second.
        When I have the PS on the bench and jumpered to enable PS_ON and VS_ON, I see proper voltages at the test points.
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          You have a bad x board, seen it dozens of times. Watch a YouTube video of how to check it.
          • clearchris
            • Dec 2013
            • 687
            I disconnected power to the x-main, still same behavior. And the tv doesn't keep trying to click on like most of the youtube videos.
            • clearchris
              • Dec 2013
              • 687
              Ok, the logic board arrived, tuner board expected to arrive friday. By my reading of how this all works, I think I can:
              1. install the logic board
              2. completely disconnect the tuner board
              3. jump PS_ON on the PS to tuner board connection
              4. run the logic board tests by jumping pins 3 and 4 as explained here:
              I'm somewhat concerned that one board may have fried the other, some I'm hoping to not plug in the suspect tuner board at all for this test. Does this sound like it would work?
              • clearchris
                • Dec 2013
                • 687
                Well that was a fail. No difference with the logic board installed.
                I did some searching and read about different samsung plasmas, and I figured out some things. There are some samsung "fast track troubleshooting manual" that also seem to be pretty detailed and useful.
                So the logic board has an LED on it, and one blink per second means "all good". Five second blink means something is wrong with X or Y. Watching the led while I plug in the box, it blinks for one second a few times, I hear a zapping sound coming from the y-main, and then the 5 second blink comes on. The zapping sound isn't loud, but it's definitely there. Disconnecting the X-main didn't make any difference, so I suspect it's the y-main board.
                I also checked Va, Vs, Vsrc and Ve, they all come up to the proper voltage for maybe a second before the power supply shuts down.
                I'm going to sleep on it, if anyone has any thoughts I'd love to hear them.
                  09-07-2024, 05:50 AM
                • ohren
                  Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                  by ohren
                  I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                  I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                  The models launched in 2018 and 2019 respectively....
                  09-08-2023, 05:24 PM
                • Nicktronic
                  Bench Test Samsung BN44-00621C Power Supply Board
                  by Nicktronic
                  Hey!
                  I've got this power supply board that's had some components replaced and I'd like to confirm all the voltages before I install it.
                  This is what I have when I plug in the board on the bench;
                  1 - N.C. - 0 VDC
                  2 - PWM_DIM4 - 0 VDC
                  3 - N.C. - 0 VDC
                  4 - PWM_DIM3 - 0 VDC
                  5 - GND - 0 VDC
                  6 - PWM_DIM2 - 0 VDC
                  7 - B13V - 0 VDC
                  8 - PWM_DIM1 - 0 VDC
                  9 - B13V - 0 VDC
                  10 - ECO_ON/OFF - 0 VDC
                  11 - Vamp - 0 VDC
                  12 - BLU_ON/OFF - 0VDC
                  13 - Vamp - 0 VDC
                  14 - GND - 0 VDC...
                  07-11-2023, 12:32 PM
                • signal.quest
                  Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
                  by signal.quest
                  I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
                  I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
                  09-30-2024, 11:21 PM
                • Eniaro
                  Bench test a series X
                  by Eniaro
                  How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
                  06-17-2025, 01:46 PM
