Samsung LCD panel a320ap20s4lv0.4. There appears vertical lines where ever there is t
  • ridaKHI
    • Mar 2021
    • 16
    • Egypt
    I have a problem with my Samsung LCD panel a320ap20s4lv0.4. There appears vertical lines where ever there is text . See my pictures.
    this problem only happen with HDMI input, not with VGA
    the picture is so good with VGA input
    Could this be fixed by cutting some kind of tracks on PCB that drives the LCD panel?
    vgh even vgh odd signal from Shift Register
    and directly connected to panel?
    Thanks for all the help in advance.
    panel: a320ap20s4lv0.4
    main board: 090-6M1814-06
    • 12199
    • U.S.
    Re: Samsung LCD panel a320ap20s4lv0.4. There appears vertical lines where ever there
    Did you try a different source, dvd player or something to rule out the pc as the possible issue or different hdmi cable?
    • ridaKHI
      • Mar 2021
      • 16
      • Egypt
      Yes, of course
        • 12199
        • U.S.
        Then reflow hdmi chip off-curse.
        • ridaKHI
          • Mar 2021
          • 16
          • Egypt
          All the vertical lines, line up exactly with the OSD text
          and hdmi input
          • ridaKHI
            • Mar 2021
            • 16
            • Egypt
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • x_orange90_x
              Samsung UN46C8000XFXZA vertical bars/horizontal lines
              by x_orange90_x
              I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
              The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
              09-04-2023, 12:09 PM
            • polaro
              Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
              by polaro
              Greetings,
              I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
              08-27-2022, 08:46 AM
              09-07-2024, 05:50 AM
            • Anonmis
              Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
              by Anonmis
              Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
              The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
              12-01-2023, 04:31 PM
