Sony KDL46W3000 TV
  • sage696
    • Mar 2021
    • 3
    Sony KDL46W3000 TV
    I have a Sony TV KDL46W3000, once the tv is turned on it's fine for a couple of minutes then the picture freezes and makes a loud static noise and the picture goes blank, then the picture appears again after a minute or so then the cycle starts over again. When the picture goes blank the backlight does go off until the picture appears again. I did replace the tcon board about a year ago due to some lines appearing on the screen seemed to have fixed that issue. I get this feeling it's it might be time for a new TV, might be a few things wrong with it. Your help on this would be appreciated, thank you.
    sage696
    • 12276
    • U.S.
    Re: Sony KDL46W3000 TV
    Maybe a bad cap or more, did you inspect the powerboard yet?
      • 12276
      • U.S.
      As always respect the HOT/DEADLY side of the powerboard, the caps can hold a charge for a while.
      • sage696
        • Mar 2021
        • 3
        Thanks for getting back to me I will check out the powerboard.
        sage696
        • CyberPhoenix
          Issue with picture quality of Sony bravia TV
          by CyberPhoenix
          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
          01-22-2024, 02:08 AM
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
        • iglitare
          by iglitare
          09-04-2025, 07:13 AM
        • tree5656
          diagnosing sony XBR-75X900H. NO PICTURE
          by tree5656
          This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
          11-09-2023, 04:55 PM
        • DKWS89
          Sony XBR 49x900E - Sound and backlight on but no picture
          by DKWS89
          Hey Guys,
          So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
          All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
          12-14-2023, 04:30 PM
