Hitachi 32HXC01UB - Intermittent Blank Screen
  • Jackplug 123
    Retired tech
    • May 2016
    • 65
    I last posted about this box of aggro in 2016 on this forum.
    It's my main set, and yes I know, I could do better..!
    I repaired the LED array in 2016 and again in 2018, it's vital to run the LEDS on LOW setting,which is what I was told to do by you guys.
    Current problem is this,occasionally screen will blank, audio is OK, shining a torch shows LED array is OFF,dim pictures still present,however on powering down by unplugging at mains supply and plugging back in 1 minute later, it sometimes fixes the fault.
    I have the TV on soak at the moment,have accessed the service menu via MENU,4725 and performed a factory reset.I did upgrade the firmware in 2016 to Phoenix V.0.8.4, think I used a USB stick and the service menu to do this.Thanks to Reeceyburger123 for the help at the time.
    Could the fault be corrupted firmware, or as I have yet to check, a fault on the power board 17IPS19-5 or the signals board VO66a 10089336 23175496.This info noted last time the rear cover was removed.
    Your help appreciated.
    Steve..
  • Jackplug 123
    Retired tech
    • May 2016
    • 65
    Re: Hitachi 32HXC01UB - Intermittent Blank Screen
    One further thought, I did have several power outages a month ago.
    The Reset for the timebeing seems to have done the trick and the TV currently works OK,touch wood!
    However any help/suggestions as to potential faults welcome!
    Cheers
    Steve
    • Jackplug 123
      Retired tech
      • May 2016
      • 65
      This Turkish delight had one more surprise in store for me, as an encore it decided to have another backlight failure!
      This will be the third repair since using the set.The backlight array seems to fail every 2 to 3 years even with the backlight set to LOW.
      Just finished fixing it and having a well earned cup of tea.
      This thread is solved for now.
      Cheers
      Steve
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Hey it could be an intermittent led I’ve had this happen before, brand new led strips are £18 on eBay and last really good have a look pal ��
        • Jackplug 123
          Retired tech
          • May 2016
          • 65
          I will do that next time it fails, the faulty led was intermittent,I run each strip of 11 leds on a thurlby power supply at 32 volts to test.Have spliced a led in for the time being.
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • Chrissygizmo
            Panasonic TX-48CX350B backlights but white screen , blank screen
            by Chrissygizmo
            Hi all, I’ve got a problem I hope someone can help me fixi.
            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
            01-11-2025, 03:18 PM
          • kotel studios
            Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
            by kotel studios
            Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
            State I got it in:
            Squealing from the PSU
            After logo I get a blank screen
            After 10 seconds of having a blank display w/ backlight the TV dies
            Give it 7-10ish seconds again and it starts to bootloop.
            What I did so far:
            Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
            Checked all voltage rails:
            5VSB - 4.8V
            AMP+13V - 14.4V
            13V - 12.98V (in manual 12V)...
            09-21-2025, 02:00 AM
          • dicky96
            HP Elitebook Screen blank - backlights but no image
            by dicky96
            Hi guys
            I'm trying to fix this laptop screen
            Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
            OK so I have the original screen which works but has lines across the bottom quarter of the screen
            I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
            04-28-2021, 07:30 AM
          • Kalman27
            Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF OLED Blank screen
            by Kalman27
            We have a Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF for repair. The original issue the OLED screen is blank.
            We have replaced the OLED screen with the exact model, also we replaced the LCD cable, but no luck.
            I think there is something with the motherboard. I don't really have experience with OLED screens so far, so not sure how it should work. I have seen some laptop comes with a separate controller board, but this model does not.
            Also, there is an error in Windows device manager - This device cannot start (Code 10) - Intel(R) Serial IO I2C Host Controller...
            06-17-2025, 05:52 AM
