22le357ou , hitachi tv . Spi chip u10 dump required .
  • zen
    • 511
    Hi all
    Hoping someone can help .
    MAIN BOARD = MSD306.3B
    SPI CHIP REF = U10
    SPI CHIP MANUFACTURER = GIGADEVICE
    SPI CHIP TYPE = 25Q32SIP
    DISPLAY = BOE HT215F01-100.
  • zen
    • 511
    Re: 22le357ou , hitachi tv . Spi chip u10 dump required .
    Loaded some files from a Bush make , version of this set & it now powers , plus produces a good picture.
    Logo at start up is Bush , instead of Hitachi , but that not an issue .
    What is a problem though is that the on board button configuration differs , but even this won't be a problem , providing i can find out what model Bush TV the files are from & order a remote control for it .
    • zen
      • 511
      Googled main board number , adding bush .
      Model seems to come up as BLED22FHDL8
      Might take a chance & order up a remote for this model.
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • hyperwood
        [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
        by hyperwood
        I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
        The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
        I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
        āœ… What I need:
        • A working 2MB BIOS dump
        • Matching NM-E471 Rev. 2.0, e.g. JY575
        06-25-2025, 02:28 PM
      • tyler123456
        Need help identifying an IC chip on a Bush DAB radio (BD-1801)
        by tyler123456
        Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
        I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
        I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
        Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
        Anyone...
        08-16-2024, 12:51 PM
      • Andreas_de
        Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
        by Andreas_de
        Hello!
        i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
        Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
        Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
        04-12-2025, 10:38 AM
