philips 55 oled 745 /12 3 blinks
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Re: philips 55 oled 745 /12 3 blinks
    i didnt check that when i had jumpers on ,i just checked the other plug for 12v and 24v which were good
    i will reconnect jumpers as before and measure this voltage ,
    it will be in the morning ,
    thanks for all your help and advice so far
    • jimbofz
      • Apr 2013
      • 539
      • uk
      when i did the first test with jumpers ,i did not check the 24v voltage on the same socket ,but i did check the 12 and 24v on the other plug and it was correct.
      i will check tomorrow the pins on the other sockets labelled+24-a
      • jimbofz
        • Apr 2013
        • 539
        • uk
        Originally posted by Diah
        when you did the first test with jumpers, did you have on the same socket 24V?
        remember you wrote before it read 12 !!!
        the pins on the sockets labeled +24V_A
        good morning
        i refitted the links as before and the +24_A voltage is 12.5v
        • Diah
          • Feb 2013
          • 6419
          Originally posted by jimbofz
          good morning
          okay... you need to do 2 other test.
          1- keep this test in place. slide out the 2 cable of +24V_A from the mainboards side .. then turn on.. see if it jump higher than 12.5V at PSU side
          • jimbofz
            • Apr 2013
            • 539
            • uk
            no
            voltage stays 12.5v with two cables of +24_A removed
            also no sby light but the other supplies 12v 24v still come up ok with no pic
            • Diah
              • Feb 2013
              • 6419
              no
              you need to check your PSU. specially the 24V line MOSFET if they are for 24V or 12V. the print say 24V..
              • jimbofz
                • Apr 2013
                • 539
                • uk
                #27
                ok will do
                • jimbofz
                  • Apr 2013
                  • 539
                  • uk
                  #28
                  the chassis type is tmp 19.6e and i managed to get cct for tmp18.1e
                  its similar.
                  the 12 and 24 v supplies are produced by the tx t9101,the components are all fine on the secondary of the tx.
                  on the primary we have a drive ic ssc 3s 927 this feeds vgh and vgl to two fets q9101 and q9102
                  with psu removed all components test good
                  the tx o/p pins 8 and 9 should produce 24v,
                  it only produces 12.5 v
                  the same tx pins 10 and 7 produces 12 v
                  and is good
                  the same winding on the primary pin 2 and 3 is used to feed the same 12v and 24v
                  so i dont know why the 24v should be low?
                  • Diah
                    • Feb 2013
                    • 6419
                    can you show focused high resolution photo on both side of the PSU. and remark on the photo the 24v_a pin
                    also did you checked after crack at the soldering !!
                    EDIT: i am afraid if the printing label wrong LOL but the 24V are very common range to supply audio section too .. other wise i will do this test.....>
                    you can try after you are sure its should be 24V. to put every things in place as original. and just slide the 2 wire of +24V_A from PSU socket. and test them with DM if they are both connected at mainboards so you can feed only one from the 24V of the panel 24V PIN and then turn on.. LOL
                    so the set should turn on with complete picture .... or it could jumping high to the moon... LOL so funny issue.
                    EDIT: Don't do this test
                    • jimbofz
                      • Apr 2013
                      • 539
                      • uk
                      #30
                      heres some pics of psu
                      i have soldered any joints that might have looked bad with magnifier
                      although the board still looks like new
                      with regards to the +24v_pins , they are joined together
                      • Diah
                        • Feb 2013
                        • 6419
                        one things more.. you wrote at your picture 24V_A read 12V at STB... so it mean it booted high to 24V after PSU turn on... same way to some of Philips PSU which they read 12V STB then goes high to 18V after turn on.. !!!! mysterious
                        • Diah
                          • Feb 2013
                          • 6419
                          it make no sense to me if +24V_A read 12V at STB as you stated.. can you recheck this point at yours photo https://www.badcaps.net/forum/attach...2&d=1613402078
                          • jimbofz
                            • Apr 2013
                            • 539
                            • uk
                            #33
                            i also think it makes no sense
                            ive reinstalled the psu as original state with all connections back to normal
                            and ive re checked the +24v and its 12.5 v in sby and 12.5 v when its blinking
                            ive tried with dm set to peak hold and it wont go above 12.5v
                            • Diah
                              • Feb 2013
                              • 6419
                              clean this section in the photo ... ist from you or some one play on PSU before you ?
                              • Diah
                                • Feb 2013
                                • 6419
                                no
                                leave this line +24V_A , because when you take them out no STB LED on the set... somethings wrong by label.
                                you need back to the last test to see if the panel damaged or not... you need to plug out the 2 LVDS cable between mainboards & T-CON ( from T-CON Side ) and do the jumpers test as you did first time.. to see if the panel still show lines or it light whole the screen... if its just line as before it shorted.. no need to spend time on this set.
                                • jimbofz
                                  • Apr 2013
                                  • 539
                                  • uk
                                  #36
                                  ok will do the mark on board is a minor scratch nothing to worry about .
                                  i will fit the links again and do the lvds foils one at a time and post the results
                                  • Diah
                                    • Feb 2013
                                    • 6419
                                    No. both Lvds must be disconnected together
                                    • jimbofz
                                      • Apr 2013
                                      • 539
                                      • uk
                                      #38
                                      ok will try tomorrow thanks
                                        its similar.
                                        and is good
                                        Can you upload the chassis TMP18.1E schematic that you are using?
                                        • Diah
                                          • Feb 2013
                                          • 6419
                                          • Diah
                                            Guide : Philips OLED TVs how to remove the protection mode NVM.EED
                                            by Diah
                                            OLED Cells over all OLED brands are easily its drooping more currents will be increase which it trick the SOS signal which T-CON driver boards will send to the Mainboards... the NVM software on the Mainboards will shutdown the PSU..
                                            not all fault at OLED are bad-- some issue can remain working with minimal issue at displaying generate
                                            Philips OLED TVs. we can switch the protection code to off via binary.
                                            - ropy it on empty usb stick and insert it while the tv off at USB 1
                                            -turn on the Tv it will restart 2 or 3 time then plug out the stick and turn on the...
                                            04-21-2024, 03:21 PM
                                          • djordje
                                            Philips 55 oled 804/12 red light blink
                                            by djordje
                                            Hello all,
                                            I have Philips Oled 55 (804/12) with black screen and red light blink.
                                            I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                            Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                            When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                            My questions is what should i do next...
                                            01-03-2025, 04:00 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
