TOSHIBA 40L3453DB red-green blinking light
  • Fergal22
    • Feb 2021
    • 50
    • United Kingdom
    Hi, just need a bit of advice please
    I have a Toshiba 40L3453DB tv with the blinking red/green light and the light grey screen but no picture or sound
    there are no swollen caps as far as i can see
    I have searched the forum and found this thread for the smaller size tv
    https://www.badcaps.net/forum/showthread.php?t=58640
    which recommends redoing the firmware, so i have searched and the only firmware i can find is this one
    h**ps://repairalltv.com/toshiba-40l3453db-software-17mb95-download/
    the 17MB95 board is the same as mine but the Panel model panel number is slightly different to what they show on that link, there's is Panel NR- VES400UNDS-03
    mine is VES400UNDS2DR06-2D-R06
    I have download the file and all it contains is the "upgrade_mb90.bin" file
    Does anyone know if this will work and will it flash using this by powering on holding the ok button down on the remote or do i need mboot and usb_auto_update_A1 file to go with it like in the other thread on here in the first link?
    I have attached pictures of my boards, any help would be appreciated
  • Diah
    • Feb 2013
    • 6360
    Re: TOSHIBA 40L3453DB red-green blinking light
    Originally posted by Fergal22
    if the firmware name you downloaded upgrade_mb90.bin and its size about 108 MB then its core firmware should work.
    • Fergal22
      • Feb 2021
      • 50
      • United Kingdom
      Ok i tried doing it but nothing happens
      I have found more software for the "32W1333DB" which is the smaller model tv than mine and the folder is called "CORE UPDATE ONLY, USE THIS IF SET WORKING - v2.1.9Z" in the folder there is a "upgrade_mb90.bin" file and a PDF called "MB95_Core-SW_update.pdf"which i have attached
      It says that the "upgrade_mb90.bin" file is only used if the tv is working and you do it through the menu's, my tv is not working so cannot do this
      It also states
      "IMPORTANT:
      There exist 2 Core-SW files for MB95 models:
      a) for models with DVB-T & -C tuner (D/DL/L/W133x / 134x based models)
      b) for models with DVB-T & -T2 & -C tuner (D/DL/L/W135x based models)
      Notice: Files for T2 models have nearly double file size.
      As both Core-SW files must be named “upgrade_mb90.bin” in order to be detected by the set, make sure, NOT to mix up files for T and T2 models !
      Flashing a wrong Core-SW can lead to malfunction of the set after updating !"
      so it looks like i need a file package containing 3 files like the one "ReeceyBurger123" uploaded for the "32W1333B" but for the "40L3453DB" model tv which i have but cannot find one anywhere containing the following files for my model TV
      mb90_en.bin
      mboot.bin
      usb_auto_update_A1
      any further help would be appreciated
      • yokoono
        • Apr 2010
        • 481
        Below you will find 2 softwares for 17mb95. With MBOOT of 1 and 2Mb respectively.
        https://file.fm/u/x5xrafm2s
        https://file.fm/u/6ygn8fapd
        • Diah
          • Feb 2013
          • 6360
          mb90_en.bin
          mboot.bin
          usb_auto_update_A1
          use the second link thankfully yokoono provided at the his post..
          • Fergal22
            • Feb 2021
            • 50
            • United Kingdom
            Thankyou both for yor help
            Before i try it i noticed in the other thread about the "40L1333DB" tv
            ASEk94 states about commenting out certain parts of the "usb_auto_update_A1.txt" file
            https://www.badcaps.net/forum/showpo...52&postcount=9
            Will i have to do the same for my 40L4353DB" or can i just go ahead as is?
            • Diah
              • Feb 2013
              • 6360
              Man, your issue firmware... even if you flash firmware now from the Mars you can always to reflash another firmware.. why you keep talking on model didn't related to yours !!!!
              • Fergal22
                • Feb 2021
                • 50
                • United Kingdom
                A simple No you don't need to alter anything, just give it a try would of sufficed
                Politeness and manners especially to a newbie costs nothing my friend
                • Diah
                  • Feb 2013
                  • 6360
                  the other threat you are mentioned and compare to yours set .. they were not sure about firmware.. so they comment the mboot section, here at your threat i am sure of yokoono firmware 100% yours.... so no need to write "try" ..
                  if we were not polite enough.. then will never share and answer you. but if some one dont trust this forum & the answer from users, let him go to pay for recovery firmware from ebay..
                  • Fergal22
                    • Feb 2021
                    • 50
                    • United Kingdom
                    I never said i did not trust the forum, i have the upmost respect for people who have the knowledge and share and help others, i just found your reply a bit harsh towards a newbie that's all, i just wanted to make sure there was nothing else i had to do before going ahead and trying it as i did not want to run the risk of bricking it
                    Well it looks like it has bricked it as i tried the firmware from the second link yokoono posted
                    plugged usb in, turned power on and pressed and held the ok key on the remote
                    The red/green blinking light changed to a constant red, not a fast blinking red/green light as it should do so left it for 10 minutes then turned it off, removed usb stick then turned TV on again and now there is no light whatsoever on the tv. no blinking light, no grey screen no booting, its dead no life at all
                    Does anyone have any suggestions apart from throwing it in the skip?
                    • Diah
                      • Feb 2013
                      • 6360
                      show me please clear focused photo on the whole mainboards.
                      • Fergal22
                        • Feb 2021
                        • 50
                        • United Kingdom
                        Hi, thanks for the reply,
                        I have attached more pictures, my phone camera is not the best, if you let me know what particular area of the board you want to see i will take a close up shot of it
                        • Diah
                          • Feb 2013
                          • 6360
                          hmm. yours NAND from the Korean Hynix. its sector construction need specific partition.
                          its same issue with any other android tv boxes with this type of NAND.
                          so what the status you are in now.. ?
                          • Fergal22
                            • Feb 2021
                            • 50
                            • United Kingdom
                            It does not do anything now, it's like its dead
                            i have no standby light blinking and no grey screen
                            • Diah
                              • Feb 2013
                              • 6360
                              try the first link to download and play it..
                              • Diah
                                • Feb 2013
                                • 6360
                                also look closely on the mainboards... you will have ic chip with 8 pins (SPI FLASH) with label No 25 could you focused photo on it or write its full label over here
                                EDIT: should be U10
                                • Fergal22
                                  • Feb 2021
                                  • 50
                                  • United Kingdom
                                  Hi, I tried the first link firmware a few times and nothing happens, no lights, nothing
                                  I have added close up pictures of some of the chips in case that helps
                                  sorry never seen you last post i will do that now
                                  • Fergal22
                                    • Feb 2021
                                    • 50
                                    • United Kingdom
                                    There is no u10, there is a U9 with this on it
                                    RT7240A
                                    GSPICE38
                                    There is another 8 leg chip by it (U5) but its very hard to make out what it says on it
                                    • Diah
                                      • Feb 2013
                                      • 6360
                                      check again it should had label with 25L1606 or some things ells after L
                                      • Fergal22
                                        • Feb 2021
                                        • 50
                                        • United Kingdom
                                        I found U20 but there is no chip on it plus it has more than 8 pads were a chip would be soldered on there
                                        I managed to get what was on chip U5
                                        UTC RET8 (I think its an 8)
                                        LR18120MB
                                        12 01
                                        there are no other chips with 8 legs on the board anywhere
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          09-06-2024, 05:33 AM
