TOSHIBA 40L3453DB red-green blinking light
  • Diah
    • Feb 2013
    • 6498
    Re: TOSHIBA 40L3453DB red-green blinking light
    look under the cover of CI module if you find it or the downside of the boards .. and tell me under the 17mb95 you have another No
    • Fergal22
      • Feb 2021
      • 50
      ok i found the little bugga, it was on the other side of the board
      U10
      25L1606E
      ?21-126...................i cannot make out what character the ? is
      30797900
      K142072
      • Fergal22
        • Feb 2021
        • 50
        Also the number on the board is
        17MB95
        R3 050413
        • Diah
          • Feb 2013
          • 6498
          U10
          25L1606E
          30797900
          K142072
          yes this one 25L606E, the other NO no need. you need to reprogram it because its now erased or corrupted when you did the flash so tv doesn't boot
          i am putting here dumps for this 17mb95 with vestel panel.. could be help and make it booting again... and also one complete firmware which its include the file of this chip need to try too by using the side panel key of the tv
          Note. if any other users have dump please share too to this threat.
          Mega download
          • Fergal22
            • Feb 2021
            • 50
            Mega download
            Hi thanks for all your help so far, which one do i try first and is it the same procedure as before
            usb stick in then power on tv while holding ok button until i see something happening?
            • Diah
              • Feb 2013
              • 6498
              the 2 file attached need to flash them direct to the U10, by using cheap CH341A programmer adapter and One Clip for 8 pins.
              the mega file you can do it as you did before by because no response from RC so need to use the side panel..
              • Fergal22
                • Feb 2021
                • 50
                #27
                Could you recommend which one to get as there are a few different ones on ebay if you don't mind
                https://www.ebay.co.uk/sch/i.html?_f...sPageName=GSTL
                • Diah
                  • Feb 2013
                  • 6498
                  the cheaper one to you include the clip and no extra fee for shipment..
                  for example
                  you need to consider 2 option
                  1- you start to repair it your self and this mainboards will be good candidate to learn with programming .. or
                  2- easy way you buy one used mainboards with 10 more extra as same to yours or where you can upgrade yours Toshiba model with one had SAT tuner if you like... all ab to you
                  • Fergal22
                    • Feb 2021
                    • 50
                    #29
                    for example
                    I will buy the programmer and learn as it gives me something to do, i will start to read up about it while i wait for it to come and If it don't work i can always buy a mainboard
                    I still have a CY7C68013A Mini board which i used many years ago to bring VU+ clone sat boxes back to life, only used in 2 times and its been gathering dust in the draw ever since as they put paid to that way of watching P*rate tv
                    • Diah
                      • Feb 2013
                      • 6498
                      then you can use the CY7C68013A LOL or its model which cant be writing .bin file
                      • Fergal22
                        • Feb 2021
                        • 50
                        #31
                        This is what i have, is it of any use for anything nowadays?
                        I will buy the
                        CH341A 24 25 Series kit
                        Is ths the main board to get if i cannot fix it buy re programming it
                        https://www.ebay.co.uk/itm/MAIN-BOAR...8AAOSwGvZf-D5K
                        • Diah
                          • Feb 2013
                          • 6498
                          I will buy the
                          yes of course it did but need software interface to do this job.
                          yes CH341A more easy specially with clip also it can be used as programmer and serial USB to TTL too for tracing log, also you can use it afuture to program mini Arduino too with mini OLED (1$ panel ) .. it make more fun and good start to learning somethings new.
                          • Fergal22
                            • Feb 2021
                            • 50
                            #33
                            Ok i have ordered it, is there a tutorial anywhere on how to use it?
                            Thanks for all you help it's appreciated
                            • Diah
                              • Feb 2013
                              • 6498
                              it is easy to know how it work.. i attached for you 2 version of the software and the driver for windows.
                              • Fergal22
                                • Feb 2021
                                • 50
                                #35
                                Thank you very much
                                I look forward to learning something new
                                • Fergal22
                                  • Feb 2021
                                  • 50
                                  #36
                                  The programmer arrived and i connected it to the U10 25L1606E chip
                                  I had to use the Ch341A_Ver_134 software as the other one (CH341A Mini Progarammer V1.30) just said access error or could not find file every time i clicked detect?
                                  it seems to have found it ok but i did have to choose the 25L1606E from the drop down menu as there was other versions there, it seems to read it ok to, see pictures
                                  Do i just choose and write one of the dumps you attached in post 24 then see if it boots up and if it don't just try the other dump, or do i have to write the upgrade software as well afterwards using the programmer?
                                  • Diah
                                    • Feb 2013
                                    • 6498
                                    dump it first and save the dump.. then if use auto to write one of the files i attched.. it will erase the chip then check blank then write then verified write. when all OK mean the flashing fine... try both file let see .
                                    • Fergal22
                                      • Feb 2021
                                      • 50
                                      #38
                                      Ok read and saved the dump attached
                                      chose the (Toshiba_40L1333DG_U10_25L1606) file and done the auto
                                      everything went as it should successfully
                                      Do i just connect the board back in the tv now and see if it boots up?
                                      • Diah
                                        • Feb 2013
                                        • 6498
                                        hmm yours dump file look good.... i wounder why didn't boot..
                                        put back mainboards and check... if didn't boot try the other file.. we want just boot to accept the ok of the RC
                                        • Fergal22
                                          • Feb 2021
                                          • 50
                                          #40
                                          We have a blinking red/green light again
                                          what do i do now?
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
                                            Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                            09-06-2024, 05:33 AM
