Vizio D40FG9 - No power/standby
  • anupkg1985
    • Sep 2020
    • 180
    I'm working on Vizio D40F-G9 tv, there is no voltage present on the secondary side of SMPS. Fuse was blown out and found two diodes on the bridge were shorted. So I replaced it with bridge as I was not having replacement diodes. Then found the mosfet QB101 is shorted. Original mosfet was SW7N65 which I replaced with TK10P60W. Again it shorted and fuse blown. I could measure the continuity between legs of main caps with shorted mosfet so I removed mosfet. Then found the diodes marked in red (R12K J0) color are shorted, could this be an issue to make mosfet and whole circuit shorted? Or what else do I need to check?
  • R_J
    • 9632
    Re: Vizio D40FG9 - No power/standby
    The diodes are not likely shorted, they are parallel to the 0.27Ω resistor. If the mosfet was shorted drain to gate, I suspect the gate drive circuit or driver ic UB101 is bad aswell
    • anupkg1985
      • Sep 2020
      • 180
      Thanks RJ for quick reply, yes those are in parallel so looks like diodes not shorted. However mosfet is shorted on source to drain and not on drain to gate. Also what IC do you suspect?
      • R_J
        • 9632
        The driver ic, it's on the other side of the board. If at any time during the mosfet failing the +300vdc may have found its way to the gate and took out the ic. If the ic is damaged it might just turn the mosfet on hard so it just shorts again.
        Shopjimmy has 40 of them in stock. $37.95
        • anupkg1985
          • Sep 2020
          • 180
          Thanks, I have ordered one from ebay for $19, hope that will work. However I would like to repair this board as well. I could see the voltage is jumping on cap EB105 from 10v to 15V. It's connected to the Vcc of the driver IC. May be IC is trying to come on but failing as it's damaged. I could see IC labelled as RIP 37T, couldn't find anything on internet. Any replacement or alternate for the same?
          • anupkg1985
            • Sep 2020
            • 180
            One thing I want to understand, as it looks weird to me is continuity exists between -ve of main cap and source of mosfet as well as there is continuity between +ve of main cap and drain of mosfet. Is this expected? Doesn't it become a short when mosfet starts working?
            • R_J
              • 9632
              The negative lead of the main capacitor is connected to HOT ground. The source of the mosfet will be connected to hot ground via 0.27Ω resistor, The positive lead of the main capacitor will be connected to one end of the primary winding of the transformer, the other end will connect to the mosfet drain. The transformer DC resistance will be very low so it will seem like the cap positive has a short to the fet drain.
              If the mosfet is just turned ON, this will cause excess current in the primary blowing the fuse.
              Under normal operation, the mosfet switches at around 60kHz, this is how the supply operates.
              Here is a similar power supply primary circuit
              • anupkg1985
                • Sep 2020
                • 180
                Thanks for the explanation, I got it now how it should work. Also I don't see pfc section in this board, so does that mean main caps will never have voltage around 360V on it? Or am I missing anything?
                • R_J
                  • 9632
                  The main cap is only rated at 250vdc so the answer is no there is likely no pfc and the voltage should be around 160v on the cap.
                  • Nooy
                    VGA MOSfet permanently shorted and loss of MOSfet pad
                    by Nooy
                    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                    02-14-2024, 02:26 AM
                  • fharris1977
                    Vizio D50u-D1 Dead Set No Standby
                    by fharris1977
                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                    12-28-2023, 10:25 AM
                  • Dvsr
                    On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                    by Dvsr
                    Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                    I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                    After replacing the caps I started testing out the speaker. It seemed...
                    09-10-2025, 10:20 AM
                  • chestercc
                    Alienware M18x Shorted CPU Mosfet
                    by chestercc
                    I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
                    I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
                    Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
                    07-16-2022, 06:05 AM
                  • mat2k
                    iMac 2017 PSU - shorted PFC mosfet
                    by mat2k
                    I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
                    There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
                    03-13-2025, 11:31 AM
