Samsung le40a656a1f reaaaaaly slow poer up
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4536
    • Italy - Milan
    #61
    Re: Samsung le40a656a1f reaaaaaly slow poer up
    You are not following any advice, why? Have you tested the power board lonely or not? If it's not ok why are you expecting something works?
    • kavleas
      • Mar 2023
      • 24
      • Ellas
      #62
      Power supply is ok, I guess there was low voltage when not connected to the rest pcbs. Now (connected) it measures 5v and 12.8v. Anyway I've had it with this set, I think it's time to get rid of it...
      • electrocuted
        • Aug 2023
        • 39
        • alban
        #63
        Hi there, having the same television I get a weird problem. Already recapped the power supply, I can hear sound from the speaker and see backlighting turning on but no image. Looking further, the tcon (input voltage 12.8 Volts so ok) does not have avdd, vgh etc. Left side has no voltage at all. The right side with 3.3V and 1.3V seems ok. Any ideas?
        • electrocuted
          • Aug 2023
          • 39
          • alban
          #64
          The tcon is : 4046FA7M4C6LV0.4
            • 12328
            • U.S.
            #65
            Unhook ribbons from tcon to panel on tcon side and retest those tcon voltges.
              • 12328
              • U.S.
              #66
              If those voltages are still missing, maybe test the little mlc caps on the tcon for shorts or abnormal resistance, first isolate tcon by unhooking cable from mainboard to tcon and the ribbon cables from tcon to panel driver boards. That test done with tv unplugged from power.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4536
                • Italy - Milan
                #67
                No good to take posses of other one thread..!
                • electrocuted
                  • Aug 2023
                  • 39
                  • alban
                  #68
                  Two panel cables already disconnected, only cable on is the one to main board to get power. The voltage ic I see is TPS65167 and the circuit is something similar to the image uploaded. avdd and vgh are not shorted to ground.
                    • 12328
                    • U.S.
                    #69
                    Did you try test in post #66? read carefully, simple test.
                      • 12328
                      • U.S.
                      #70
                      A video is worth a million words, here's one example of tcon troubleshooting there's many many more on youtube, sometimes just buying another tcon is more economical than the time it takes to learn troubleshooting, depends on how much time you want to spend and of course if the tcon is the actual problem: https://www.youtube.com/watch?v=FexX7TGRzDc
                        • 12328
                        • U.S.
                        #71
                        Google results of your board #, you would try to match up the alphanumeric digits on the white box with the barcode on the tcon: https://www.google.com/search?client...M4C6LV0.4#ip=1
                        • electrocuted
                          • Aug 2023
                          • 39
                          • alban
                          #72
                          Thank you for the reply, the tv is not worth buying replacement part. I will try the test you suggest
                            • 12328
                            • U.S.
                            #73
                            I hear you, it's 15 years old, that being said, I still trust them much more than what samsung has been churning out for the last 7 or 8 years, tcons are usually the cheapest board to replace, have seen them for like 10 dollars or so on ebay sometimes, this model has the Red Rose accent feature and got quite good reviews in 2008: https://www.google.com/search?client...56a1f%2Breview
                            • electrocuted
                              • Aug 2023
                              • 39
                              • alban
                              #74
                              There is no short in the capacitors and diodes. And I can't find a diagram to follow the voltages on the pcb. I will try to see what happens if I connect the cable from the main board to an unused connector!
                              • kavleas
                                • Mar 2023
                                • 24
                                • Ellas
                                #75
                                Too bad I dumped the one I had, it might be of assistance with the voltages!
                                • electrocuted
                                  • Aug 2023
                                  • 39
                                  • alban
                                  #76
                                  Yes it could help if it was operational! In the meantime I connected the cable from main board to another plug (the one with the white arrow above CN1) and now it has voltages on the right side as before but voltage has appeared in the input of IC11 (bottom left corner). Nothing else though...
                                  https://www.shopjimmy.com/samsung-lj...4-t-con-board/
                                  • electrocuted
                                    • Aug 2023
                                    • 39
                                    • alban
                                    #77
                                    After many tests the tv won't work! The only one time the screen showed something and the led stopped blinking was this. What should I make of it?
                                    • electrocuted
                                      • Aug 2023
                                      • 39
                                      • alban
                                      #78
                                      No one is familiar with this type of fault, showing this image on screen?
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4536
                                        • Italy - Milan
                                        #79
                                        i know this set has very consumptive TCON with big heatsinks and fan, the age corrodes the BGA balls and needs to be reballed.. on this type of set only homemade reworking can be accepted.. i think is far too late to do this but try to put tcon on freezer for almost 1 hour, then rapidly mount it and test it, watch if it make improvements or degrades with heat.., check also temperature on the chip on normal mode..
                                        • electrocuted
                                          • Aug 2023
                                          • 39
                                          • alban
                                          #80
                                          Thanks, I'll give it a try and see what happens
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
