Samsung le40a656a1f reaaaaaly slow poer up
  • kavleas
    • Mar 2023
    • 24
    • Ellas
    #41
    Re: Samsung le40a656a1f reaaaaaly slow poer up
    Funny, voltage reached 11.5 volts and when connected to load (car bulb 60w) it dropped to 5 volts and the backlighting was flashing on and off!
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4536
      • Italy - Milan
      #42
      replace the shunt regulator for feedback, like tl431 or similar
      • lotas
        • Jan 2016
        • 4850
        • Russia
        #43
        You all changed the electrolytic capacitors in the power supply, how is the PFC (Power Factor Corrector), what is the voltage on the large capacitor in standby mode and in operation?
        • kavleas
          • Mar 2023
          • 24
          • Ellas
          #44
          Standby:315V, Power on:380V
          • kavleas
            • Mar 2023
            • 24
            • Ellas
            #45
            Removed 431 (ICM803) and it measures ok. What I still don't understand is what happened when heating the electrolytics and the voltage rose!
            • lotas
              • Jan 2016
              • 4850
              • Russia
              #46
              It is necessary to replace all electrolytes with new ones.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4536
                • Italy - Milan
                #47
                Already done Lotas..
                to the OP, you can't measure a TL431, it's not a transistor, you better change it.. to be sure grab one from a working ps just to test purpose, this because there are probably fakes on the market..
                • kavleas
                  • Mar 2023
                  • 24
                  • Ellas
                  #48
                  Unfortunately I can't seem to find a 431 to replace the existing one but it's a zener diode and it measures ok. Voltage accross led part of optocoupler PCM801 is 1v.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4536
                    • Italy - Milan
                    #49
                    it's not a zener diode you can't measure it..
                    • lotas
                      • Jan 2016
                      • 4850
                      • Russia
                      #50
                      The TL431 chip is an adjustable zener diode. It is used as a reference voltage source in the circuits of various power supplies.
                      • kavleas
                        • Mar 2023
                        • 24
                        • Ellas
                        #51
                        I get a bizarre reading when connecting ammeter between psu and mb on the 5v stand by rail. It indicates 0.5A. This doesn't seem normal (tv is turned off). Is there a schematic of the mb (BN41-00974B)?
                        • lotas
                          • Jan 2016
                          • 4850
                          • Russia
                          #52
                          Service Manual BN41-00974B
                          • kavleas
                            • Mar 2023
                            • 24
                            • Ellas
                            #53
                            Wow THAT was fast, thanks!
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4536
                              • Italy - Milan
                              #54
                              In post #41 you told the psb behaves bad also whithout the main board, so it is not important to jump to the mainboard attention.. how many tl431 are there? The one to be changed must be the one of the 13v supply stage
                              • kavleas
                                • Mar 2023
                                • 24
                                • Ellas
                                #55
                                I thought to check if something is shorted on the mb and affects the psu. I see 4 431s on power supply, I checked the feedback one. Will check the rest and try to find replacements.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4536
                                  • Italy - Milan
                                  #56
                                  You can't check a main board without a good power supply
                                  • kavleas
                                    • Mar 2023
                                    • 24
                                    • Ellas
                                    #57
                                    There is the culprit for the high current on the 5v stand by voltage! The diode and the cap are shorted. Trying to find a way to turn on the set without the panel (led,touch,infrared) connector.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4536
                                      • Italy - Milan
                                      #58
                                      pullup the ps on line..
                                        • 12328
                                        • U.S.
                                        #59
                                        If you didn't yet, unhook that board from both sides and retest the diode and cap, if they both still read short, take out of circuit the easiest one to get out first and recheck and check where they connect to the board see if the short is still there or gone, need to fix any short or tv won't work.
                                        • kavleas
                                          • Mar 2023
                                          • 24
                                          • Ellas
                                          #60
                                          I removed the grey ribbon (touch pcb) from the small pcb and the short is gone. Powering on, the cap voltage is 5 volts, ir still works but once again no image or sound. Going to remove the diode and see...
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
