Samsung Model # UN55H7150AF in startup loop
  • rplewis
    • Sep 2015
    • 82
    I'm looking at a Samsung Model # UN55H7150AF. When I plug in TV, without using the remote, the TV comes on to the splash screen and it stays on for 2 sec. goes to app screen for 15 secs then goes black for 2 secs then back to the splash screen. It continues to repeat this process.
    I used "mute+1+8+2+power" sequence to get into option screen. I got in the Option menu and it stayed on for about 12 secs then went back to the loop. I couldn't move around in option menu at all. Any ideas with TV doing as I describe?
    Attached are photos.
  • Diah
    • Feb 2013
    • 6435
    Re: Samsung Model # UN55H7150AF in startup loop
    i just wounder why it start app screen at start up... can you try to press exit or source to change it Tv sat or areal or usb or hdmi.. we need another source as soon you changed the source fast plug it out from wall socket and leave it for few seconds then turn on let see it will start to the new source or not.
    second things you need to try.. freezing the chip which it had white sticker on it by freezing it hopefully the turning time will increase so you log in service menu option and make factory reset.
      • 12272
      • U.S.
        • 12272
        • U.S.
        • rplewis
          • Sep 2015
          • 82
          Remote doesn't change source or won't change anything. Tried freezing chip but no changes there either.
          • Diah
            • Feb 2013
            • 6435
            before you was able to use the remote when you interred service menu??
            can you show me the page of app it started with before rebooting?
              • 12272
              • U.S.
              Advice not taken...advice retracted.
              • rplewis
                • Sep 2015
                • 82
                Yes.. the remote will get me into the option screen but won't work once I'm in it, nor will it operate anything while TV is in the loop process. Attached it a photo while TV is in the 15 sec. app screen.
                • Diah
                  • Feb 2013
                  • 6435
                  its normal start tv as it show the portal on down line..its chip corrupted.. you need to do reset first via service menu to see if it correct the chip
                  • Diah
                    • Feb 2013
                    • 6435
                    your photos it show the set are on TV source...
                    if the TV tuner got defect or shorted of any reason the issue will be same as you have..
                    plug the TV with internet LAN cable. and as soon the the screen show you as the photo very fast move on RC with right arrow to the app next to TV and press OK..
                    • rplewis
                      • Sep 2015
                      • 82
                      Lan plugged in, still no response from remote or toggle switch on back of TV.
                      • Diah
                        • Feb 2013
                        • 6435
                        try use air mouse or USB one, we need only one click on any app
                        • rplewis
                          • Sep 2015
                          • 82
                          Tried everything I have.... no luck moving to right, left, up or down...
                          • rplewis
                            • Sep 2015
                            • 82
                            When I push the buttons on the remote... I see the red standby LED quickly flashing but nothing on the screen happens/changes.
                            • Diah
                              • Feb 2013
                              • 6435
                              last check ... unplug one ribbon cable between t-con and panel and test if it same issue remain...
                              • rplewis
                                • Sep 2015
                                • 82
                                No good...
                                • Diah
                                  • Feb 2013
                                  • 6435
                                  No good...
                                  LOL.. disconnect any things connected to main boards leave only the LVDS and the socket with PSU... if no good... time to replace MB or use heat instate feeze to the chips i told you
                                  • rplewis
                                    • Sep 2015
                                    • 82
                                    No luck.... Been looking for main board.... everyone is out of stock or not cost effective.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4456
                                      • Italy - Milan
                                      You still buy Samsung? It's a hammer hit onto the balls... better to move to another brand maybe.. Panasonic high end models? Sony? The goal of Samsun is to fullfill our green fields and beaches of end of life devices. The.story of programmed faults must end instantly, no more time for environment disasters.. say fu** you to big industries of the bad businesses. Go to recycle isle and take an old CRT tv without softwares, nobody really needs smart tv.. I'm still using everyday a last CRT tech tv by Sony, at least 16-18 years everyday use and very often left on all the night, never a fault, image still perfect. Never bought a plasma/LCD tv.
                                      • Takeatry
                                        Yet another Samsung QLED Boot Loop
                                        by Takeatry
                                        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                        10-04-2024, 02:57 PM
                                        09-07-2024, 05:50 AM
                                      • eigma
                                        Samsung UN40H5003 boot loop every ~8 seconds
                                        by eigma
                                        Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                        Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                        SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                        Main board: BN94-07592P / BN97-08922R...
                                        11-20-2024, 10:31 PM
                                      • brkie
                                        Samsung UE75TU6905 reboot loop
                                        by brkie
                                        I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
                                        I read on Samsung's website (reviews)...
                                        09-04-2024, 01:45 AM
                                        09-06-2024, 11:40 PM
