Lg oled65e6p-u.buswljr
  • rplewis
    replied
    Re: Lg oled65e6p-u.buswljr
    Unplugged from wall, waited 10 mins. Plugged back into wall and TV started in STB mode. Turned TV on with original remote. Pressed IN STOP on SRV remote. I didn't see any changes on TV and the voltage at the 24 volt socket is still 1.23 volts.
    I'm assuming the TV is suppose to go back into STB mode when I press IN STOP?
  • rplewis
    replied
    I did start with original remote, forgot to say that in reply. Going to try it all again.
  • Diah
    replied
    Originally posted by rplewis
    My bad...LOL. It started in STB but didn't do anything when I pressed INSTOP with LG SRC remote.
    i wrote to power it on with ORG RC if it start at STB then send instop .... waiting your result
  • rplewis
    replied
  • Diah
    replied
    no luck
    what do you mean with no luck? set didn't start or you cant send instop???
  • rplewis
    replied
    no luck
  • Diah
    replied
    nothing happening... acts like it doesn't recognize remote actions
    while its on plug it out from wall socket... wait 10 minutes then plug it back.
    if it start at STB turn it on with Original RC.. wait it turn on then send INSTOP with LG SRC
  • rplewis
    replied
  • Diah
    replied
    Just got back. Had a power outage right in the middle of our progress. I did the same as earlier to start TV.
    "powered with original remote. LED on front is now out, the red LED on main board is on. All voltages on PS except 24 V socket. No image on screen panel."
    Do I need to resume from what you said earlier?
    "while the set on, send with LG SRC IN-STOP follow it with 0 4 1 3 the set will goes to standby.. leave it in this STB state for at least 10 seconds then turn on the set FROM the SET POWER at the set ( Not from any RC ) give attention on the screen and test the 24V after it complete
    of course you need to do this step..
  • rplewis
    replied
  • rplewis
    replied
    Originally posted by Diah
    no lol
    its at the side panel of the tv or at the front it should be like joystick
    Yes... that's the one I'm referring to....LOL.
  • Diah
    replied
    if you dont find it now... use only the original RC to power on after In_STOP
  • Diah
    replied
    the SET POWER on the set is the main power button?
    no lol
  • rplewis
    replied
    okay...
    now we will try to reset the t-con "micom" firmware as we know from stand alone test it wasn't started and the main firmware too to clear all the previous errors you got before..
  • Diah
    replied
    okay...
  • rplewis
    replied
    so its now at standby????? if yes use original remote to turn on
  • Diah
    replied
    please do only what i am asking you exactly.. and response here little faster
  • Diah
    replied
    No LED on main board. Didn't hear relay on PS. Did not use remote
  • rplewis
    replied
    good so the mainboards wake up but still in protecting mode.. do the exact and report the result.
    1- since you power on the set and you have the optical audio output led lid red... dont turn off the set with RC... just plug it off from wall socket.. and wait 10 seconds and plug it in wall.. tell if it turn on or not.. give time for the booting.
  • Diah
    replied
    Tried again and heard relay on PS click, now there is a red LED on the main board. Checked voltages on PS... got all voltages except the 24 volt socket... it reads 1.231 volts
  • AK_777
    Sony KD-65A1 Repair – 4 Red Blinks Error
    by AK_777
    Hi everyone!
    I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
    Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
    02-20-2025, 04:15 PM
  • BakaMonogatari
    LG 65UJ6300 no backlight unless TCON disconnected.
    by BakaMonogatari
    Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
    TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
    11-04-2021, 12:36 PM
    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
    09-07-2024, 04:30 AM
  • ugamazing
    by ugamazing
    12-17-2024, 07:05 PM
  • maxim2511
    LG 55EC930V OLED - swich on swich of no screen
    by maxim2511
    My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
    Then I get an idea to take it apart and clean boards from dust.
    In side of Tv was not so bad, I take compressed air in can, and gently blow up.
    Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
    05-14-2021, 02:21 AM
