Lg oled65e6p-u.buswljr
  • Diah
    replied
    Re: Lg oled65e6p-u.buswljr
    Originally posted by rplewis
    struggling to get this remote IR working. The wave file only plays for less than a second. Attached is photo of IR remote.
    if you use VLC program you can toggle it to play the wav endloss to test the ir with camera.. you use the pins of the diode IR at the bottom side
    and dont forget to be sure the socket on the pc some had headphone output and microphone input
  • rplewis
    replied
  • Diah
    replied
    Never done the remote IR before. I've taken the IR circuit board out of remote. So I need to get a stereo headphone plug with wires attached to the ground of the post and one connected to the center of the post. Where on the IR board do I connect these 2 wires? Would it be the positive and negative battery connects? Also, how long should this wav file play? The one I've got here only last a second.
    no battery should be at yours RC, the cable connect them direct to the IR sender pins.
    play wave once. test your work with your mobile camera until you can see the IR blinking once red or more.. then play it to the tv
    you may need to try all the jack cable until you see with camera the blink of IR
  • rplewis
    replied
  • rplewis
    replied
    Sorry for the repeat message... the firs wasn't showing up.
  • rplewis
    replied
    All sockets look to be correct. Nothing appears to be cut or binding. I do remember when I first started diagnosing, that there were lights on the main board ( I think 2 of them). Now there is no lights on the main board.
  • Diah
    replied
    All sockets look to be connected properly. I have no red LED lights working on the main board. When I first started diagnosing, there where LED lights. (I think 2 of them)
    it may the mainboards went to blocking mode..
    you should success with the following:
    i posted for you all wav. files at post #60 unzip them and use Power Only wav.. play it on the pc with WinAmp program or VLC .. be sure on the PC the headphone volume full 100% and main volume too
    take any ear or headphone jack and connect the the end wire of them to IR sender, you can take it out from any remote control you have..
    ( notice the + & - of the IR ) + to the center of the jack and - to chassis or out pin )
    let the IR led face the tv and play the wave.. to be sure it send signal you can use your mobile camera focused on the LED IR sender it will blink when you play the wave file... use only Power Only wave all you need at this time.
  • rplewis
    replied
  • Diah
    replied
    Stays on solid with no blinking at all when I press the power button on the TV or remote.
    cant be.. check all sockets on the main boards of the front Led.. you may have one cutting or not in place
  • rplewis
    replied
  • Diah
    replied
    Sorry about that... not the smartest marble in the bag...LOL! I saw that T-Con board. I will order it. Do you think I should order the main board too?
    you need to look at the front led indicator of the lg when you turn it on by pressing power.. did it blinking and then back to stand by?
  • rplewis
    replied
  • Diah
    replied
    I thought I found a T-Con board but I don't think it will work. All the numbers and letters on the board are right but the TV model number is different. My TV model is OLED65E6P-U.BUSWLJR and the T-Con I found is OLED65G6P-U. With the TV model being different, do you think the T-Con I found would work or should I try to find one with the same model number?
    Man.. i wrote many time yours mobile didn't work because it hadn't IR blaster
    about T-CON you can check this or any same with less price
    it show to me here 32$
  • rplewis
    replied
    not having any luck with remote on the phone.
  • Diah
    replied
    there are DIY you can do it self IR Led and audio jack to play .wav file from pc they will be as LG service remote... how to solder search after it here or on web.. i attached the file for you
  • Diah
    replied
    Disconnected the 12V connector from T-Con... no help.
    I used file explorer to move the apk file to phone. After install, it won't start. It shows that the app shut down. Looked on play store and just not sure which remote to get. You have any idea?
    yours Galaxy S8 didn't have IR Blaster so this option not for you,,, S5 did and some of xiaomi
  • rplewis
    replied
  • rplewis
    replied
  • Diah
    replied
    I've got a Galaxy Note S8. How do I put this zip file on it. Can I get it on play store?
    Galaxy S8 didn't have IR Blaster,,, S5 did and some of xiaomi
  • Diah
    replied
    if you have freeze spray -- you can try freeze the T_CON main ic and other chips who knows it could help
    EDID:
    also you can disconnect only the 12V socket at T-CON and turn on... hopefully main boards will let the T-CON to step at other stage than this SOS
  • AK_777
    Sony KD-65A1 Repair – 4 Red Blinks Error
    by AK_777
    Hi everyone!
    I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
    Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
    02-20-2025, 04:15 PM
  • BakaMonogatari
    LG 65UJ6300 no backlight unless TCON disconnected.
    by BakaMonogatari
    Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
    TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
    11-04-2021, 12:36 PM
    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
    09-07-2024, 04:30 AM
  • ugamazing
    by ugamazing
    12-17-2024, 07:05 PM
  • maxim2511
    LG 55EC930V OLED - swich on swich of no screen
    by maxim2511
    My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
    Then I get an idea to take it apart and clean boards from dust.
    In side of Tv was not so bad, I take compressed air in can, and gently blow up.
    Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
    05-14-2021, 02:21 AM
