Stand Legs Screws - Standard Size?
  • jstiene
    • Feb 2013
    • 148
    Hello.
    I am in need of ordering replacement stand screws for a few different TV's...TCL / Vizio / Hisense. They all seem to be similar screws. I think they are M4 x ??. Does anyone happen to know what the most common size and length size is and where I can get them in bulk?
    Thanks for any recommendations in advance.
  • neilc6
    • Nov 2015
    • 1550
    Re: Stand Legs Screws - Standard Size?
    If you google for the users/quick start manual for your particular model, size is usually listed there. No universal standard but LG typically uses M4x12. Samsungs typically use the same as the back case. A taptype with course threads.
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • DXseekerMO
      Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
      by DXseekerMO
      Hello everyone!
      Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
      Symptoms:
      1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
      2) TV does not appear to turn on
      3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
      4) "Power on" terminal on Power Supply has 3.26v
      5) "A13V" terminals have 12.9v
      6) Stand-by test jumper on Power Supply has 12.9V
      7) Optical audio jack on Main Board illuminates
      8) With stand-by...
      06-09-2021, 12:19 AM
    • FriedFred
      Schenker VIA 15 PRO, PF 4NU1F V1.0, P/N: MBPPF4NU18-F310 - 36mA in stand-by
      by FriedFred
      Hello, everyone!
      I have here a Schenker VIA 15 PRO, with this numbers on the board: PF 4NU1F V1.0 and P/N: MBPPF4NU18-F310 .
      I took out the memory and the battery and the SSD.
      So, in stand-by, only the board, takes 36mA. No power-button pressed at all, I can measure 1.8V, 3.3V, 5V. All coils present voltages except the two power rails for the CPU. The CPU is a AMD Ryzen 5 4600H.
      After pressing the power-button, the current raises to 500mA and the two power rails for the CPU show up with 0.8V.
      After several seconds, the fans switch-off and the board keeps powered...
      03-08-2025, 04:45 AM
    • Titus6
      LG OLE65C1 Stand-By issue
      by Titus6
      I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
      However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
      I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
      01-31-2025, 04:01 PM
