Lg lcd
  • tornedoar
    • Aug 2019
    • syria
    Lg lcd
    hallo.
    I have an LG LCD TV, 37LG30r-TA.
    the backlight is working well but no screen, no data on a screen, just the lights only is working.
    all Volts from a Power supply is good, the 1.8V on T-con is good too, the voltages 8v ..etc on main board also existing.
    what is your suggestion?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Lg lcd
    Can you post photo's of your boards especially your tcon board. 1.8V does not sound right.
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • advant
      by advant
      02-03-2020, 12:25 AM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
    • maxim2511
      LG 55EC930V OLED - swich on swich of no screen
      by maxim2511
      My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
      Then I get an idea to take it apart and clean boards from dust.
      In side of Tv was not so bad, I take compressed air in can, and gently blow up.
      Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
      05-14-2021, 02:21 AM
    • alltvrepairs
      Lg TCon test pins for screen test
      by alltvrepairs
      i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
      Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
      Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
      Appreciate your help....
      06-13-2025, 06:33 AM
