Discharging a CRT TV
  • sam67
    • 256
    Just picked up an old Hitachi color tv that has been stood maybe for a couple of years ..The tv works but i have not plugged it in ..I want to gut all the components out of it i. e pcb and desolder some of the the parts for practicing with.
    My question is even though it has been stood so long i was gonna discharge the crt with an insulated screwdriver with a wire with alligator clips attached and ground one end while touching screwdriver under anode cap just to make sure theres no voltage lurking ..Then i was gonna use multimeter on big caps before i desolder them ..Once this is done can i desolder all the parts from power supply side and everything else without any problems.
    Seems a shame to dump the tv when i can use the parts for testing rather than going out buying parts while i am learning Reason for tv not been used is it is no good over here now everything has gone digital ,plus it was just in a spare room doing nothing.
    Cheers
  • mockingbird
    • Dec 2008
    • 5484
    Re: Discharging a CRT TV
    I don't know about dischargind the caps, but this is how to discharge the tube:
    1) Take a flat-tipped screwdriver and a solid thick wire.
    2) Coil the wire around the screwdriver tightly so that they make good contact
    3) Attach an alligator clip to the end of the wire
    4) Attach the alligator clip to the spring which goes along the left side of the tube next to the Aquadag.
    5) Touch the flat tip to the metal clips underneath the suction tube. You should hear a pop.
    With a TV that is old, you will have to discharge it many many times until you hear no more pops. Wait a half hour in between discharges. Some here have mentioned that it it impossible to fully discharge a really old TV.
    Interestingly enough, I have so far discharged only two newer TVs with a recent manufacture date, and eventhough they have been used extensively, the tubes on them for some reason never kept any significant charges.
    • sam67
      • 256
      Thank you for the tip ..Will do it later on .
        • 30985
        if you dont want the tube then why bother discharging it?
        the cap has two prongs under it, going right&left.
        if you hold the back of the cap with thumb & finger and push it sideways one side will unhook.
        then lift a little and move it the other way and it will be off.
        the transformer doesnt hold any charge.
        wear rubber gloves if your unsure - and *dont* hold anything with the other hand.
        • sam67
          • 256
          Cheers guys ,
          Got the pcb out last nite with out any problems..This set is over 20 years old lol even the caps still look good ..dropped the pcb though and cracked it never mind i only want it for practicing purposes
          Will try my new ESR meter out that i got off Mike the micro v4 see how the caps are after all this time. Must say that mike does not mess about when sending stuff and he is a pleasure to deal with..Highly recommended and great communication from him.
          Thanks once again Mike.
            • 30985
            how much was the mk4 inc post to the u.k. ?
            • sam67
              • 256
              Hi stj ,sorry for late response only just seen post ..£47.85 inc p+p..
              Quick question as it saves me posting another thread.. I have some caps that i have been measuring and then checking with data sheet .. say for example 1000uf 16v with a 20% tolerance is this tolerance already worked out on the data sheets or does it have to be added ..as i measured some caps that were 1000uf 16v that were 0.18 with esr meter and when checking manufacturer data sheet the caps should be 0.16 just wondered if data sheet leaves you to work the tolerance out ..I know it may sound like a dumb question but just wondered while i am learning using the data sheets correctly.
              Thanks in advance.
              • sam67
                • 256
                Should have said that the price was $75 and the price in pounds at the time was £47.85 when i bought mine the exchange rate was not as good. Best to contact mike .
                • sam67
                  • 256
                  Forget the question regarding the tolerance as i had a dumb moment and was thinking that the tolerance was for the esr when it should have been for the uf lol.
                  • Radio Fox
                    • Jan 2010
                    • 281
                    Originally posted by sam67
                    ...Will try my new ESR meter out that i got off Mike the micro v4 see how the caps are after all this time. Must say that mike does not mess about when sending stuff and he is a pleasure to deal with..Highly recommended and great communication from him...
                    Did your ESR-micro V4.0 have the batteries already fitted?
                    My meter arrived this morning, but with no batteries. I'm not complaining, it's just that, if I knew in advance that batteries were not included, I would have bought some beforehand.
                    ________________________________________________
                    Invisible airwaves crackle with life
                    Bright antennae bristle with the energy
                      • 30985
                      probably safer not to ship stuff with battery's,
                      if it goes into a plane then the cargo will get decompressed - the pressure-drop may make the cell's leak!
                        • 30985
                        double-post!
                        • sam67
                          • 256
                          Hi guys ,
                          No mine did not come with batteries ..Mike did tell me before i ordered as it can cause problems at customs and Mike wanted to deliver as quick as possible without any hold ups..You can get the batteries off ebay really cheap ,that's what i did.
                          One of the best tools i have bought and the meter seems to be really accurate so no complains from me and a big thumbs up to Mike..I am a beginner in this field as i have already stated but devices like these really do help whether you are newbie like me or professional..
                          I am also looking at his Fly back tester ..but i am still finding my way around and learning as much as i can let my brain take lol.
                            • 30985
                            i made my own flyback ringer using a schematic.
                            http://members.ozemail.com.au/~bobpar/fbt.htm
                            • Radio Fox
                              • Jan 2010
                              • 281
                              Hi guys ,
                              No mine did not come with batteries ..Mike did tell me before i ordered as it can cause problems at customs and Mike wanted to deliver as quick as possible without any hold ups..You can get the batteries off ebay really cheap ,that's what i did...
                              Didn't have time to shop around. I wanted to play with my new toy straight away
                              Just come back from my local supermarket. Luckily they had some Energizer 2032 batteries (£1.80 each).
                              • sam67
                                • 256
                                I got some maxwell 2 lots (4 Batts) for £2.18p inc p+p off ebay but like you say you did not want to wait.At least you can have a play about though now lol.
                                p.s just checked my ebay purchase .
                                  • 30985
                                  99p stores in the u.k. often have a card of them - for 99p
                                  • Mark D
                                    Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                                    by Mark D
                                    The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                                    10-29-2024, 03:15 PM
                                  • DynaxSC
                                    Extreme High Current & Low Voltage Short Killer ??
                                    by DynaxSC
                                    Hi Folks
                                    I'm looking for a extreme high current short killer solution for a reasonable cost.
                                    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                    After taking off the socket, the shorts dissappear again.
                                    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                    10-15-2024, 10:13 AM
                                  • 2elw
                                    SVOD4 PCB pictures + parts
                                    by 2elw
                                    Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                                    STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                                    GW1N-UV9UG169C6/I5 FPGA - Its a...
                                    07-04-2025, 12:23 PM
                                  • SurrealMustard
                                    What parts can be salvaged from a plasma with a damaged display panel?
                                    by SurrealMustard
                                    I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                                    03-09-2025, 08:29 PM
                                  • DynaxSC
                                    Asus Rog Strix B360-I Gaming - Parts Identification
                                    by DynaxSC
                                    I have an Asus Rog Strix B360-I Gaming with missing parts. I know there is a resistor missing for sure, but nearby it seems there might have been also a transistor or mosfet. Below the picture of the area on the board with the missing parts. The interesting area is inside the rectangle.
                                    I'd appeciate if somebody could make a detailled picture of this area from a working board and post it here. Getting the parts values would also be helpful. The revision of the board is 1.02 .
                                    Thanks in advance...
                                    08-23-2023, 07:56 AM
