Hitachi 42HXT12U - Not working - Standby LED Flashes
  • Jack828
    ultimate n00b
    • Dec 2020
    • 15
    Hello fellow tech geeks!
    I've recently come into possession (a freebie!) of a Hitachi 42HXT12U LED TV which does not work.
    It does the following:
    - Plug in
    - Standby LED flashes alternating RED and BLUE approx 6-7 times
    - Does this approx twice
    - Standby LED stays solid BLUE
    I've opened it up and had a look at the PSU board (which is a 17IPS20 23145828) for any bulging caps and there aren't any.
    Any ideas folks? If you suggest replacing the PSU board then I'll go ahead and do it - only about 30 quid off ebay.
    Thanks!
  • yokoono
    • Apr 2010
    • 481
    Re: Hitachi 42HXT12U - Not working - Standby LED Flashes
    Find software for main 17MB95 and panel VES420UNDL-N01
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Take some voltage readings from CN4 and report back.
      • Jack828
        ultimate n00b
        • Dec 2020
        • 15
        Not sure I follow what you mean?
        It's pretty wacky to be honest. I unplugged the cable so I could get readings and I got this:
        1 - PIN_1 - 0v
        2 - GND - ok
        3 - ST_BY - 0v
        4 - GND - ok
        5 - BL_ON-OFF - 0v
        6 - GND - ok
        7 - PWM_DIM - 0v
        8 - GND - ok
        9 - +5V_STBY - 0.1v
        10 - +12VCC_S - varies between 7v and 11v, not stable at all
        11 - +12VCC_S - same as above
        12 - +12VCC_S - same as above
        Hope that helps, thanks for your input.
        • Jack828
          ultimate n00b
          • Dec 2020
          • 15
          Sorry for the double post but I figured a way to measure whilst the unit is plugged in.
          Here's the readings:
          1 - PIN_1 - 0v off, 24.29v when powering up
          2 - GND - ok
          3 - ST_BY - floating, ~2v when powering up
          4 - GND - ok
          5 - BL_ON-OFF - 0v
          6 - GND - ok
          7 - PWM_DIM - 0v of, 3.3v when powering up
          8 - GND - ok
          9 - +5V_STBY - 5.3v
          10 - +12VCC_S - can't reach whilst plugged in
          11 - +12VCC_S - 12v bang on
          12 - +12VCC_S - can't reach whilst plugged in
          EDIT: Tested what I think is the LED inverter power (no idea, the black/red 2 wire connector at top of board) and it just floats between -1v/+1v.
          Double EDIT: Tested between red wire + chassis as ground and I get a bunch of different readings. Sometimes 180-190, sometimes just falling from 120, can't seem to get it stable
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            It looks like you have no BL-ON-OFF (Backlight On) control signal being fed to the power supply from the mainboard.
            What dc voltage do you have across C105 (ie between the two legs of that capacitor.)
            What voltage do you have on each wire of CN501 as you power up.
            Edit
            Those results are generally indicative of faulty led(s) or connection between the led strips.
            • Jack828
              ultimate n00b
              • Dec 2020
              • 15
              C105 - 393v
              CN501 - Black - Started at 80v, goes down to 11v, then jumps back to 80v after another power on
              CN501 - Red - 118v, then jumps around between 180-190v
              Roger that, lets hope not.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                C105 is one of the large capacitors 47uF 450V
                • Jack828
                  ultimate n00b
                  • Dec 2020
                  • 15
                  Sorry, my bad I managed to find it after looking again more closely - 393v.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    So it's not the PFC voltage being too low. It does unfortunately look like a led(s) or led strip problem.
                    • Jack828
                      ultimate n00b
                      • Dec 2020
                      • 15
                      Gotcha. Will look into that to see if I can't just replace the faulty ones or if I have to get the all the strips. Thanks so much!
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        You may just have a bad connector or connection on one of the led strips interconnection so I would check for continuity between strips.
                        The panel uses a number of different strips to complete the array.
                        Type A and Type C are shown in this ebay listing. It's the way they fit together within the panel.
                        https://www.ebay.co.uk/itm/183802199613
                        so you would need to match any replacement strips accordingly.
                        • Jack828
                          ultimate n00b
                          • Dec 2020
                          • 15
                          Righto, managed to get the whole thing apart to check the LED strips.
                          Continuity between strips is fine, but putting the multimeter on diode mode and probing the little + and - test points doesn't make any of them light up at all.
                          EDIT: TIL, you can scratch the solder mask off and test each LED individually, just gotta figure out what goes where!!
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            Do you have continuity between the two strips when testing with your multimeter.
                            If all the led strips are connected in series and they are 3v leds, then the driving voltage would be around 48 x 3.2V = 153V. There is a200V capacitor near to CN501.
                            Have you tried powering up the setnow that the panel is removed to see if the leds flash?
                            • Jack828
                              ultimate n00b
                              • Dec 2020
                              • 15
                              Yes, there is continuity between strips.
                              Haven't tried powering it up again yet but I'm pretty sure I've more than one blown led on almost each strip, just figuring out which is +ive and -ive traces is tricky - should have another update tonight.
                              EDIT: Looking at the moment that I need 3xA and 1xC strips.
                              • Jack828
                                ultimate n00b
                                • Dec 2020
                                • 15
                                So I am aware (and sorry again for the double posting!) what does it mean if the backlights either DO or DO NOT flash when powering the unit up without the panel in?
                                I assume if I have one or more dead LEDs that the LEDs will not flash at all, and if they do flash we have a power issue.
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  Short circuit led will often allow the remaining leds in the circuit to light up momentarily and an over voltage will be seen by the led driver IC which switches off the drive to the leds to stop further damage.
                                  Open leds (or open circuit led strip connector) will as you say not light up however the tell tale sign here is that the led voltage rises up quickly beyond the normal led driving voltage and then collapses just as quickly.
                                  • Jack828
                                    ultimate n00b
                                    • Dec 2020
                                    • 15
                                    Sure, makes sense.
                                    Just plugged it in now and no LEDs lit up.
                                    I'm guessing next steps is buy a LED strip pack and replace those?
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      Do a Youtube search on how to test leds on the led strips. I would not be replacing the strips until I was certain I had found the fault.
                                      https://www.youtube.com/results?sear...+tv+led+strips
                                      • Jack828
                                        ultimate n00b
                                        • Dec 2020
                                        • 15
                                        I did manage to test the LEDs individually - see attached for the believed broken ones.
                                        • Bazilwrc164
                                          Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                                          by Bazilwrc164
                                          I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                                          The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                                          I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                                          If anyone can provide:
                                          • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                                          • Or a compatible EEPROM dump
                                          07-23-2025, 12:15 PM
                                        • Nicktronic
                                          Samsung UN70NU6070F Standby Light flashes twice
                                          by Nicktronic
                                          Hey Everyone,
                                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                          03-27-2023, 07:01 PM
                                        • provider10
                                          Samsung UA46ES5660 standby light flashes
                                          by provider10
                                          Hi
                                          Got this Samsung LED tv. Plug set in standby light comes on steady. Switch on Standby light flashes 2 times for a sequence of 5.On the psu I only get the a5v coming out. Disconnect PSU from Main board, backlights come on and all the PSU voltages come up. When in fault mode there are no voltages on any of the regulators on the main board. Yet the processor must be working otherwise it wouldnt change when the set is switched on. Also none of the chips on the main board are getting warm.
                                          The PSU board is BN44-00502C
                                          Hoping soene can help
                                          02-09-2022, 01:38 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
