Philips 65PUS7803/12 is only turning on video 1 out 5 times
  • Repair_dane
    • May 2020
    • 42
    • Danmark
    For a month now my Philips 65PUS7803/12 has had problems on startup.
    It boots up every time, but 4/5 times it has no video. Sound and LEDS are on.
    You can shut it down and try a couple of times again and eventually it will come on after 4-5 times.
    It stays on and for the next hour or so it is possible to turn on the tv at once first try.
    It also has a pretty high standby voltage for an hour or so after shutting down (14 Watts +/-). After an hour it will drop to a more decent 0,1W
    I am pretty sure it is a main board fail since everything else is endeed working, but I might be wrong.
    What do you guys think?
    I want to avoid opening the tv if I can. these 65" screen are too big for me to handle without cracking the panel and if it is the mainboard I can't repait it anyway
  • William1967
    • Nov 2017
    • 217
    • Netherlands
    Re: Philips 65PUS7803/12 is only turning on video 1 out 5 times
    The TV is from 2018, is the 2 year warranty over? If not contact the shop where you bought it.
    • Repair_dane
      • May 2020
      • 42
      • Danmark
      Nice try. Warranty over. Reciept gone missing anyway
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Philips documentation for your set says
        • Standby power consumption: <0.3W
        so if you have 14W for an hour or so I guess it's not going fully into standby and is a possible power supply issue. No real way of knowing for certain without the back coming off and doing some measurements.
        • Repair_dane
          • May 2020
          • 42
          • Danmark
          Thank you for this answer.
          Power supply I can work with. There some screws in the bottom of the back cover. I hope it is possible to open it this waay. I'll try this weekend and give an update how it went
          • Repair_dane
            • May 2020
            • 42
            • Danmark
            It seems that the issue was the t-con.
            I get 12V on the tcon fuse, but it stops after the first transistor.
            I have no voltage on cofs when screen isn't working, but voltage when it does.
            Can anyone help with ordering a spare transistor? I can't figure out how to identify it
            It says 34P F7
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              12V on both sides of the fuse?
              • Diah
                • Feb 2013
                • 6610
                It says 34P F7
                dont play with yours t-con-
                just downgrade the firmware.. here you are
                under nur 2018 download only with upgrade_loader files with .pkg format
                • Repair_dane
                  • May 2020
                  • 42
                  • Danmark
                  Yes
                  • Repair_dane
                    • May 2020
                    • 42
                    • Danmark
                    Thank you for the advice. Though I doubt it is that easy I will give it a try
                    • Repair_dane
                      • May 2020
                      • 42
                      • Danmark
                      Update: problem solved
                      Updating the firmware did not help
                      I ordered a new t-con from aliexpress and installed it. TV came on immediately and has been working ever since
                      • Nicktronic
                        Philips 75PFL5704/F7 A Video Issue
                        by Nicktronic
                        Hey everybody, got a strange one here.
                        The TV will display the Home Screen, Menus, Netflix Home Screen, YouTube home screen with preview tiles, etc, without issue. As soon as I try to play video (streaming or from any of the HDMI inputs), all I get is audio and and blank screen. It's like the video is not being processed. So I ordered a replacement main board. I can now play video from streaming sources but the video from HDMI sources is all green (kinda like photo negatives but all green) and the audio does not work. Is it possible the main board I ordered is also failing?? I can't...
                        10-31-2023, 05:43 AM
                      • JarzabekPZ
                        HP Victus 15-fb0104nw not turning on, charging led blinks 3 times
                        by JarzabekPZ
                        I'm working on a HP Victus that is not turning on. When power button pressed it only blinks 3 times with charging led. I have checked input mosfets and they are fine. Also all coils are fine too. Battery was empty but I charged it with my lab PSU and laptop started on batery but is not charging. When battery is disconected and only PSU connected it takes 0 current and not starting. What can be the reason?
                        09-18-2025, 08:16 AM
                        HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                        This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                        09-12-2024, 02:00 PM
                        GeForce RTX2080 Super Aero video gaming card issues help need
                        by sam_sam_sam
                        This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                        Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                        05-07-2023, 08:12 AM
                      • Ierwin
                        Philips 58PUS7805 Menu working but no/weird picture from video sources
                        by Ierwin
                        I got a 58pus7805 that shows some weird behavior.
                        The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
                        However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
                        I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
                        I managed to install the latest official firmware by holding the control button while plugging...
                        03-10-2024, 12:50 PM
