Sanyo FW55D25F will not turn on
  • itronic
    • Sep 2015
    • 82
    • usa
    This tv has will not turn on. I unplugged ribbon cable (c5n01) going to mainboard and still no backlights. I unplugged led connection (cn1401,cn1201,cn1101) and check with a backlight tester and each set came on. Im thinking PSU is bad.
    PSU Power test with mainboard unplugged and led plugged up.
    check from ground to each point on cn501 connection:
    1. 0
    2. 0
    3. 0
    4. 0
    5. 0
    6. 0
    7. 0
    8. 0
    9. 0
    10. 0
    11. 0
    12. 0
    13. 0
    14. 0
    15. 8v
    16. 8v
    17. 8v
    18. 8v
    19. 0
    20. 13v
    21. 13v
    22. 13v
    23. 13v
    Any help will be great. Thanks in advance.
    Here is the boards in my tv.
    https://www.shopjimmy.com/sanyo-fw55...w-970672831097
    Here is close up of another PSU that will work for a DS2 series tv with back of board picture to.
    https://www.shopjimmy.com/sanyo-a5gr...2-serial-only/
  • itronic
    • Sep 2015
    • 82
    • usa
    Re: Sanyo FW55D25F will not turn on
    Okay, UPDATE:
    Tried another PSU, done same thing as last PSU did. Same readings and they both chirp. I can unhook mainboard and chirping stops. So ordering main board today.
    Also, anyone know how to make the PSU come on by itself.
    thanks in advance.
    • itronic
      • Sep 2015
      • 82
      • usa
      UPDATE:
      This model needs main board to make PSU come on.
      The main board was bad. So after installing , everything works great now.
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
      • RdeveLabs
        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
        by RdeveLabs
        To all the members here...
        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
        05-05-2025, 04:59 AM
      • robante15
        Acer Aspire 4520 won't turn on after reboot
        by robante15
        Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
        It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
        The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
        If I remove the...
        04-06-2024, 06:50 PM
      • masoksian
        Dell latitude e7470 not turn on .power buton on off and Run Power problem
        by masoksian
        I am dealing with the problem of turning on and off my Dell e7470 notebook.
        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
        The system does not turn on, there is no post.
        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
        The problem continues in the same way.
        I tried to turn on the Fn key, nothing came to the screen....
        02-15-2025, 12:08 PM
