Re: Skyworth 40E360 indicator always green
Those chinese do keep us guessing for sure.
sorry for the late response.. the LM1117-33 as i trace it goes to the heatsink ic .this unit has a 3 in 1 ic. china made unit is well known for this crap. as i recall i happen to check also another 3.3 volts buck converter that also powers the main ic. can't see the ic number, IC is glued tight to the heatsink actually in my desperation i try to pull it out but with no avail .. i don't investigate that further because this unit has been with me for 1 week and the client is eager to pull it back..sorry for that.. i cant answer it anymore the unit has been handed to the client.. schematic is not available to pin point exactly where the output of the 1117 is going..sorry for that... china made tv is really unpredictable they have their own standards,, my opinion.. thanks again for journeying with me...
we are happy you solved the problem.. but are you trying to tell us here the U9 under the heat sink of Main IC ??? this never never happened DC to DC converter which supply Power line 3.3V VCC shared with NAND /Standby/ LED Status Green&RED, Tuner.. Main IC.. will be under heat sink.... this will never being TRUE.Leave a comment:
Good job, you should upload the pictures of the LDO regulator and also provide the designator of the LDO for future repair for other people.
Voltage test is one of the thing to test when troubleshooting, bad Voltage can give you goose chase.Last edited by budm; 10-26-2020, 05:57 PM.Leave a comment:
Glad to hear it, another save.Leave a comment:
yah near the processor with heatsink.. i thought i need to take off the heat sink to reveal the eeprom.. hehehe i forgot this unit is a smart tv all things in my mind jumbled just to repair thing as fast as i can.. maybe next time ill take time.. thanks again..Leave a comment:
So it's fixed then with a new Ic regulator?Leave a comment:
thanks for the help guys i already repair the skyworth led tv ..i already done that using usb drive with no avail. the unit is in comatose no backlight no respond to anything i do even using the firmware i downloaded in skyworth pressing the menu while pluging it on the main to read the usb drive the drive lit but just steady.. sad to say its not a firmware problem but one of the 1117 3.3volts ic regulator very low output 1v with input of 5v that powers the processor. that is why it makes weird symptoms... thanks a lot guys really appreciate all your help.Leave a comment:
Nice work Diah, yep looks like you need a wifi usb dongle and a usb flash both, for the update, hold that menu button til update starts.Last edited by nomoresonys; 10-26-2020, 05:07 AM.Leave a comment:
The firmware update is readily available from Skyworth.Download,and follow the instructions!Leave a comment:
sorry for that my bad..i appreciate all your time and effort for helping. i just search for that on the net that says eeprom ic EN25Q32 for the skyworth 40E360 but honestly i can't find it. i look everywhere in the mobo.. maybe i just overlooked it. ill try again. i'm just spending a lot of time with this unit. i dont know, but honestly im lost,. the 4 tv's that is brought here last week is already done prior to this skyworth tv.. and 2 of that have corrupted eeprom i already reflashed it and fix it. ill update you for the progress.. i'm really sorry for my attitude.. peace...
In general to any one want to trouble shooting TV need to know first how it work and which system (firmware) platform it had. if you keep searching on SPI you didn't found.. but you have NAND. it mean the set work as same method android or Linux depend on boot loader saved on NAND. this is yours start point to search firmware and flash it via USB 1. as i read this main boards need WIFI USB dongle connected to USB 2 then the flashing start at time while pressing Menu on side panel then plugged the set in wall socket.Leave a comment:
See the two 8 pin components, can you read the numbers on them or make out their designator beside them? One just might be your EN25Q32.Leave a comment:
SKYWORTH 40E360 mainboard # 5800-A6R81S-0P30 VER 03.00
that sop8 ic near the lcd strip connector is me9435A mosfet i really can't find the spi eeprom
ive got a clear picture of the mobo got on the netLast edited by Duranitron; 10-25-2020, 07:25 AM.Leave a comment:
.Last edited by nomoresonys; 10-25-2020, 06:28 AM.Leave a comment:
I think one of the problems is there's a few different mainboards for this tv model, what are all the numbers on the two thin white stickers on the mainboard?Last edited by nomoresonys; 10-25-2020, 06:45 AM.Leave a comment:
sorry for that my bad..i appreciate all your time and effort for helping. i just search for that on the net that says eeprom ic EN25Q32 for the skyworth 40E360 but honestly i can't find it. i look everywhere in the mobo.. maybe i just overlooked it. ill try again. i'm just spending a lot of time with this unit. i dont know, but honestly im lost,. the 4 tv's that is brought here last week is already done prior to this skyworth tv.. and 2 of that have corrupted eeprom i already reflashed it and fix it. ill update you for the progress.. i'm really sorry for my attitude.. peace...Last edited by Duranitron; 10-24-2020, 10:16 PM.Leave a comment:
It's no use Diah...he can't even find it.Leave a comment:
I did NOT say it was a fix, I said it's a test to try to narrow down the problem, pay attention, maybe work on reading comprehension before popping off.Last edited by nomoresonys; 10-24-2020, 01:05 PM.Leave a comment:
by jimjoe123I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
Then each time... -
This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-12-2024, 02:00 PM
This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD,...09-07-2024, 03:10 AM
This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i7-1195G7, 16GB, 1TB SSD, Full...09-07-2024, 03:10 AM
This specification for the Acer Aspire Aspire Vero Green PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire Vero Green PC boardview and Aspire Vero Green PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-07-2024, 02:20 AM
- Loading...
