LG32LN5300 No standby voltage no power
  • anupkg1985
    • Sep 2020
    • 180
    I'm working on LG power supply where I'm not getting any voltage on the board. I'm getting fluctuated voltage from 12v-15v on C103 on primary side. Also getting voltage fluctuations on pins of IC101. I replace all ceramics on primary side however same issue. Also tested mosfet Q101 looks good. Can some one tell me whats going wrong here?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG32LN5300 No standby voltage no power
    What's the part number of the power supply. Pictures are difficult to read off.
    • anupkg1985
      • Sep 2020
      • 180
      It's EAY62810301 Power Supply for LG 32 inch LED tv. C103 I'm getting fluctuating voltage on C103 is 100uf 50V which I already replaced and IC is SC1S311.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        This may be the power supply schematic
        Have you disconnected the mainboard from the power supply and used a 1K resistor between standby 3.5V and PWR then checked the voltages at the output?
        • anupkg1985
          • Sep 2020
          • 180
          I'm not getting stand by 3.5V on the secondary side. Could that be IC issue?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            It looks like SC1S311 is attempting to work but failing so trying again which is probably why the voltage is jumping around.
            Here is the data sheet for SC1S311.
            I would be checking that there is no physical damage to the IC and next check the components around it.
            • dokma
              • Aug 2017
              • 39
              • Croatia
              Try checking the R103 and ZD105 feeding the startup voltage to the IC101. If they are leaking, IC101 could be on the way out.
              • anupkg1985
                • Sep 2020
                • 180
                I tested both r103 and zd105 and looks good to me.
                • R_J
                  • 9633
                  Check that R113 is not open, It is likely the VCC voltage you are measuring could be from the startup cell in the ic itself. Check that R112 and the transformer winding are not open.
                  It is possible that the ic is bad as in no drive.
                    Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                    by sam_sam_sam
                    I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                    https://www.ebay.com/itm/116497313155?var=416785404161
                    Here are some of the description from the eBay seller
                    The main parameters:
                    1. Product name: High-power non-isolated DC boost module power supply.
                    2. Product model: 100A2000W.
                    3. Input voltage: DC12V-60V.
                    4. Input current: 100A (maximum)....
                    05-18-2025, 09:45 AM
                  • meraklinetx
                    Asus Z97-a power cycle, no boot no cpu voltage
                    by meraklinetx
                    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                    05-10-2023, 06:08 AM
                  • reessi
                    JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                    by reessi
                    I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                    You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                    Years ago it had some bulging caps...
                    04-26-2021, 11:42 AM
                  • stylishconsultant
                    un60j620dafxza - Samsung No Display Problem
                    by stylishconsultant
                    Hi All,
                    Need help.
                    I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                    So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                    problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                    might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                    09-04-2024, 03:26 AM
