Hisense - 50N4(Backlights on 12v is 2v)
  • Amraks
    • Nov 2011
    • 725
    Brand: Hisense
    Model: 50N4
    PSU: rsag7.820.5687
    mainboard: rsag7.820.6526
    Symptoms:
    Backlight is on no picture.
    Front LED flashes 6 times
    12v line is reading 2v
    the rest of the voltages are fine.
    Filter cap voltage is 379 - 380v
    Checked over diodes so far.
    Not sure where to go on this one.
  • Amraks
    • Nov 2011
    • 725
    Re: Hisense - 50N4(Backlights on 12v is 2v)
    Some photos of mainboard
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Are you certain the 12V supply is low.
      The backlight IC (N901) is supplied by 12V_VCC which is derived from V806 fed from the 12V supply? So if the backlight is operating then I believe that the 12V supply must be working.
      It may be a problem with a connection between power supply power lines going to the mainboard. Possible solder joint at one end.
      • Amraks
        • Nov 2011
        • 725
        could there be a short on the main board putting it into protect mode?
        I did notice the 16v is only 12v
        also notice two caps on the mainboard are short
        c1062 c1063
        • Amraks
          • Nov 2011
          • 725
          Well I took the shorted cap from the mainboard out of circuit and we have a picture now tv works should I replace this cap?
          Also the chip is
          2m = 3d 71f
          • Amraks
            • Nov 2011
            • 725
            I just replaced the cap with 50v ceramic tv works
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Good repair. Another one saved from the rubbish dump.
                God job indeed.
                • Amraks
                  • Nov 2011
                  • 725
                  couldn't get a datasheet for that chip but I believe that line is supplying 30vs to that chip.
                  just a lucky repair which paid off.
                  hope this thread helps if someone has the same issues.
                  • hasini
                    • Jan 2021
                    Thanks for sharing that :-).
                    Tested same 2 capacitors on my Hisense 50N4 which were both shorted.
                    Removed C1063 and got video on the screen again :-)
                    Thanks so much.
                    • Mrzoop
                      • Jan 2021
                      Amraks, thank you for posting this. Great find!!
                      Just like you and Hasani noted, I also had a short on C1063. I have removed the capacitor and have corrected the problem. Video is back on as normal on my 55N4.
                      One question I must ask, should a new capacitor be installed? What are the risks of leaving it removed?
                      Thanks again, appreciate your assistance.
                      Hisense HA55K3140WT/213693/E170303 RSAG7.820.6526/ROH
                      • trink80
                        • Feb 2021
                        Hi Guys,
                        i've got the same problem with my 55N4, can you please tell me the exact replacement capacitor, I'm a novice.
                        Cheers
                        Joe
                        • Mrzoop
                          • Jan 2021
                          Also the chip is
                          2m = 3d 71f
                          If you have a short on C1063, then simply remove it.
                          I asked the same question if it needs to be replaced and it hasn't been answered yet..... but my TV is working without it. To get you back on, just remove it.
                          • Jembang
                            coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                            by Jembang
                            good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                            11-01-2024, 09:55 AM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                            by sam_sam_sam
                            07-01-2024, 06:34 AM
                          • dabushar
                            Hisense 55'' Issues Mainboard or Power Supply?
                            by dabushar
                            Hi Guys, i have a tv i bought a mainboard for (a hisense 55H8E) because it just stopped working. When i replaced with the new motherboard. The TV comes on displays the logo and starts up fine.
                            When i load or connect an input or play a youtbe video the backlight disappears but the audio and video remain. Anyone Experienced such? I have attached some pics of the old board the new board the power supply and the model.
                            If anyone can assist id be grateful....
                            10-01-2020, 02:12 PM
