Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
  • novak2
    • Jul 2020
    • 32
    • France
    Hello there,
    I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
    The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
    From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
    Thanks in advance.
  • petehall347
    • Jan 2015
    • 4434
    Re: Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
    take a look and see if any bulged ones
    • novak2
      • Jul 2020
      • 32
      • France
      There's no bulged caps, but there were some, after testing them, that were faulty. I replaced them but the problem is still there.
      I have 2 relays on the power board, but it looks like there's only one working at start up. Any help ?
      • novak2
        • Jul 2020
        • 32
        • France
        Ok, I tested all the caps, they are all good. What could it be ?
        • novak2
          • Jul 2020
          • 32
          • France
          Ok some news here. It seems to be the video board, because when I unplug it, the TV stays eletrically on (nothing on screen, but I think it's normal since I removed video and RF board)
          • novak2
            • Jul 2020
            • 32
            • France
            So, more news.
            When I disconnect the AV/RF board, turn on the TV, and hot plug it in, the TV works. But now, I have no sound, speaker worked fine berore.
            • novak2
              • Jul 2020
              • 32
              • France
              Here some pics
              • novak2
                • Jul 2020
                • 32
                • France
                So, let me recap this.
                The TV is a Panasonic TH-42PX60EN plasma. When the power cord is plugged and the power button pressed, the TV clicks, attept to turn on, and then shuts off, then it retries again and again. After some fast analysis on the power board, there is NO bulging cap visible. This is the same for the other boards, no bulging caps apparently. When I disconnect the power cable of the AV boards (where there are HDMI in, SCART in etc...), the TV tries to come on, but it last LONGER than before. Sometimes, after 2-3 attempts, I can turn on the TV by unpluging the power cable of the AV boards, power on the TV, and hot plug it in. The TV works fine, except there is no sound. Speakers works tho, so I think it is just a problem on the audio procesing part of the AV boards. When I turn the TV off, if I don't wait too much time, I can put it back on perfectly without hot plug out/in the power cable of the AV boards.
                So here's some theories :
                - There are multiple (or just a single) bad capacitor on the power board that has not bulged, but is just weak, and so the TV needs some time to power on by charging slowly the capacitors.
                - There are some problems with the AV boards, maybe bad caps or overheated chips (the overheating one might be for the audio in this case).
                I also precise that :
                - This TV is second hand, I bought it cheap because the problem with the clicking relay was known.
                - This TV has been torn down for cleaning by the previous owner, and I didn't found any kind of thermal pads on the AV boards where it seems to need it, when I disassemble it myself yesterday.
                - I cannot found anything for this problem for THIS exact model. I found many articles/videos that talks about it for other TVs, always some kind of caps bulging, but I apparently have none.
                So what do you think about this ? Do you think it is worth trying to rescue this ? (I think so, plasma is a beautiful screen)
                • petehall347
                  • Jan 2015
                  • 4434
                  see if anything is getting very hot once you tricked it into switching on .. maybe is the audio chip gone shorted .
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    have you tested the capacitors using a esr meter? maybe try heating different boards up with a hair dryer before turning it on this may narrow down the board at fault and meybe then the area at fault
                    • novak2
                      • Jul 2020
                      • 32
                      • France
                      I don't have an ESR meter, I just have a multimeter that can measure capacitors.
                      • novak2
                        • Jul 2020
                        • 32
                        • France
                        So, after some heating tests, ot turns out that the ADV7499B runs VERY HOT when I use HDMI source. The two other chips runs slightly warm but it looks okay. Also, the TV booted first time without the help of hot pluging. Also, there is some "THERMAL PAD" written on the board, but I didn't find any.
                        • novak2
                          • Jul 2020
                          • 32
                          • France
                          So, the board concerned is TNPA3756. I just bought another one, if I can have my sound back by replacing the DG board. If you have any advices concerning the current board, and the probably overheating audio chip, I'll be glad to test them.
                          Also, my TV seems to boot normally, without any kind of repeating clicking noise. So maybe, it was the audio chip that was overheating (or just shorted), and to protect itself, the TV shuts off automatically. Now that the chip is probably fried (at least not fonctionning), the TV boots.
                          • novak2
                            • Jul 2020
                            • 32
                            • France
                            I found this : https://en.ppt-online.org/323141
                            It might be useful.
                            • novak2
                              • Jul 2020
                              • 32
                              • France
                              lil bump and lil news.
                              Since I need to wait for the part to come, I tested different thing. And guess what ? The board TNPA3759 doesn't work ! Or at least SCART plugs seems to be dead, except that when I plug an RGB cable (not a composite cable over scart), and turn on the device, it recognizes the RGB signal, but there is nothing (except some interferences noise, but very very little, and my cables aren't good so I know that it might be that), but still, no picture ! and no sound still of course. Anyone knows how the H, DG, D boards are working exactly ? I'm confused since I just bought the DG board... I'm worried if it will work or not...
                              • novak2
                                • Jul 2020
                                • 32
                                • France
                                So, since I don't have any analog video, I digged into the service manual. And I have some theories about both audio issue and analog video issue, that will lead into my initial one (which has been fixed by some magic trick lol)
                                - For the audio, I highly suspect the H board, expecially the MSP (multi signal processor). As I said, I don't have ANY audio on ANY output (even headphones), and it was working before. Maybe I screwed that with the hot plug in when I tested some things. Totally my bad on this one I guess.
                                - For the analog video, I have 2 suspects :
                                - the Video Input Select chip, but I'm not confident in this one, I don't think it is.
                                - the ADC chip on the DG board that is just before the RGB processor. I think it might be this one that is faulty.
                                So, I can have 2 situations :
                                1) The H board is litterally the only one faulty, with a bad MSP/VIS/Capacitor (or anything that can be shorted)
                                2) The H board AND the DG board are faulty, the H one is for the MSP, and the DG is for the ADC.
                                So I prepared for the second one. I just bought the DG board AND the H board. I bought both for a total of 30€ (~35$). Since I bought the TV for only 20€, it will probably cost me 50€ (~58$) to have it fully fontionnal.
                                Also, I think that the TV wasn't booting properly because of one or both board faulty, and to protect the circuit it was just shutting off. But I can assure you that it is from DG board or H board, or both. I will tell you once I have my boards if it worked.
                                Edit : frickin missclick tab and enter lol.
                                • novak2
                                  • Jul 2020
                                  • 32
                                  • France
                                  So, here again for delivering some news.
                                  I received the DG board, and what a surprise ! It didn't solve the sound output and analog video input, but, I have a slightly better picture over HDMI, AND the original problem is now completely gone !
                                  Now waiting for the H board...
                                  • novak2
                                    • Jul 2020
                                    • 32
                                    • France
                                    Hello there.
                                    I received my H board, and guess what... NO SOUND AND NO AV ! There is a serious problem here, because I don't know where the problem is !
                                    HELP PLEASE !
                                    • novak2
                                      • Jul 2020
                                      • 32
                                      • France
                                      Just to inform you.
                                      I did the self-check, and AVSW1 and AVSW2 failed both.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        possible faulty replacement h board as AVSW1 and AVSW2 failed (av switch)
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • Lintesir
                                          Panasonic P42S30 Plasma - Pink sparkles
                                          by Lintesir
                                          My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                          There is about a 5cm high region at the top without any sparkles,...
                                          07-26-2024, 03:16 AM
